Quantcast Tailgate lock same as doors? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tailgate lock same as doors?
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 08-04-2003, 08:43 PM   #1
Jimmylh
Can anyone tell me if the tailgate lock is the same lock the doors use? I have no keys that fit any of the locks. The ignition was swapped and uses a gm ignition switch with it's own key so it does not fit anything else on the Jeep. I can find plenty of places on the web that sell door lock sets but I can't find anything at all on the tailgate lock. Thanks.
Jimmylh is offline   Reply With Quote
Old 08-04-2003, 09:20 PM   #2
wm69
You could probably get all 3 rekeyed to match as cheap as you could get 3 matching lock cylinders new..... Go ask a locksmith, if he's too high you might have lost 20 min.
85 CJ7 258, borla header, jacobs ign, weber carb,optima batt, 135 amp alt, agr super box 2 & pump, T5 w/ B&M shifter, centerforce 2, superior 1 piece axles, warn hubs/ XD8000i, 2.5 in lift, 31" BFG MT
85 CJ7 "wife's ride" 258, A/C, T176, superwinch hubs, 3in lift 31" BFG AT/KO
wm69 is offline   Reply With Quote
Old 08-05-2003, 12:09 AM   #3
jeepinkg
They are the same....but if you plan to buy new ones just go to the lock smith and have them match and cut a key for them..Its not expensive maybe 20 bucks depending where you go...i had it done and 2 keys cut for 12 bucks from a professional lock but that was for the console which they had to remove the lock but they wont have to do all that just swing by or call them you will save some money
95 YJ
2in body, TJ flares,32's, detriot true trac up front, powertrax no slip rear, mile marker winch, and more
current projects
400 big block, ford 9, dana 60, and some more lift
jeepinkg is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
