tail lights stopped working? - JeepForum.com
post #1 of 11 Old 08-09-2010, 01:20 PM Thread Starter
b3llo38
for some reason my 2 tail ligths and center tail light above spare tire all went out, when i put my headlights on the running tail lights do work though, but not when i hit the brakes during the day no lights turn on, could this be a blown fuse or what? and if so which fuse is it??
4cyl Jeep YJ 1995
BNIB Brown Dog 1" Motor Mount Lift (make offer)
BNIB Currie 1" Body lift (make offer)
b3llo38 is offline
post #2 of 11 Old 08-09-2010, 01:23 PM
carterfarter
Sounds like the switch connected at the top of your brake pedal went out to me.
carterfarter is offline
post #3 of 11 Old 08-09-2010, 01:30 PM Thread Starter
b3llo38
yea im gonna have to wait for someone to get home to test this with me, is it a hard fix?
4cyl Jeep YJ 1995
b3llo38 is offline
post #4 of 11 Old 08-09-2010, 01:31 PM
pasinbuy
I believe that you horn is also brake lights. Does your horn work?
pasinbuy is offline
post #5 of 11 Old 08-09-2010, 01:40 PM Thread Starter
b3llo38
yea my horn works fine
4cyl Jeep YJ 1995
b3llo38 is offline
post #6 of 11 Old 08-09-2010, 01:40 PM Thread Starter
b3llo38
my mechanic told me to look for a blown bulb in one of them and replace it because they can short each other out? that doesnt make sense to me but its a cheap enough fix to try
4cyl Jeep YJ 1995
b3llo38 is offline
post #7 of 11 Old 08-09-2010, 01:43 PM
NoVaHunter
Run, quick! Its gonna blow!
But seriously, its probably a bulb or the switch.
Originally Posted by KHoff90 View Post
Has anyone really been far even as decided to use even go want to do look more like?
NoVaHunter is offline
post #8 of 11 Old 08-09-2010, 01:48 PM Thread Starter
b3llo38
yea ill wait a little bit to go out an swap the bulbs, its 100 degrees out right now
4cyl Jeep YJ 1995
b3llo38 is offline
post #9 of 11 Old 08-09-2010, 02:06 PM
Louie4
My turn left turn signal and horn stopped working and soon my tail lights were out. I finally figured out the plug on the column had been partially pushed out when I reinstalled my A/C unit under the dash.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #10 of 11 Old 08-09-2010, 02:06 PM
hallsofstone
Had the same thing happen with my lights about a month ago. Thankfully the new bulb solved the problem entirely, it was the frist thing I tried. Hope it works out the same for you!
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #11 of 11 Old 08-09-2010, 02:10 PM Thread Starter
b3llo38
yea, i also noticed my right blinker light in the dash stays lit when i turn my lights on.. hmm hoping its just a bulb
4cyl Jeep YJ 1995
b3llo38 is offline
Stock fog lights stopped working ew0341 TJ Wrangler Technical Forum 3 08-15-2009 11:51 AM
tail lights not working correctly, passesnger side tail is dim. kbarwall TJ Wrangler Technical Forum 2 08-19-2008 09:22 PM
instrument lights stopped working Mr. Joshua TJ Wrangler Technical Forum 4 06-12-2008 04:18 PM
fog lights stopped working today wrnglrguy TJ Wrangler Technical Forum 5 11-16-2006 03:42 PM
Brake Lights stopped working kearns TJ Wrangler Technical Forum 3 02-16-2006 02:57 PM
