tail light again !!!! - JeepForum.com
post #1 of 6 Old 07-11-2012, 04:33 PM Thread Starter
jasjeep08
2005 KJ Liberty
Hello every one, well just removed rear corner diamond plates off my 88yj, I had to remove my tail lights and when I put them back on my (R) tail light doesn,t seem to be working correctly when i turn on my lgts the bulb is dim and the marker/small bulb stays on, do the screws act as if there grounds to the body? The screws are rusty and the back metal is rusty.
jasjeep08 is offline
post #2 of 6 Old 07-11-2012, 04:56 PM
soonermatt
Clean all the rust? I just replaced my tail lights and I think there's a ground in the housing.
soonermatt is offline
post #3 of 6 Old 07-11-2012, 05:10 PM
bigbossd1030
They are grounds, clean the heck out of them. I would replace the bolts, clean the nuts with some pb blast then use some dielectric grease (5-8$) a tube. And that should take care of it.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 6 Old 07-12-2012, 04:20 AM Thread Starter
jasjeep08
2005 KJ Liberty
Thanks for the help... I'l do so when I get home from work
post #5 of 6 Old 07-12-2012, 07:43 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Did you get this solved? I have some thoughts on what else it could be.
Poke is offline
post #6 of 6 Old 07-12-2012, 08:24 PM
tankinyj
Grounds. Happened to me. Clean em and check em
2012 JK, 44s locked on 4.56s, 4:1, 3" on clayton arms, 37" PBRs
Crush Orange Jeep Member #55
tankinyj is offline
Rerouting tail light/3rd brake light wiring... thejafe TJ Wrangler Technical Forum 3 06-29-2012 02:49 PM
tail light/break light/ dash light dont work handyman5150 TJ Wrangler Technical Forum 3 07-06-2011 03:24 PM
LED Tail light vs stock tail light CB3 TJ Wrangler Technical Forum 55 03-17-2010 11:38 AM
keep blowing tail light, turning singnals and interrior light fueses on my TJ bigtime13 TJ Wrangler Technical Forum 1 11-06-2009 06:34 PM
Tail light(brake light) Question...need help please! Bobert360 TJ Wrangler Technical Forum 3 11-17-2003 11:32 AM
