tackling the oil leak soon...wish me luck! - JeepForum.com
post #1 of 11 Old 02-13-2013, 07:29 AM Thread Starter
psych
Thanks for all the help with the radio/light issue. It appears to be fixed!
Now on to the big problem.When I bought the jeep, I was told it had a rear main seal leak. The motor and entire under side was coated in oil and stinks any time you run the thing. After talking with a friend who has owned jeeps for years, he started asking questions about what was oil soaked and he thinks instead of a rear seal, it is probably the valve cover gasket.
Sooooo, with that said, I'm going to attempt (key word) to clean all the old, nasty oil off everything and change the valve cover gasket. I've been reading on here about it and there are various opinions as to what kind of gasket to use, and so on.
Aside from all that, any tips, advice, words of wisdom, etc for me before I start? It'll be at least the weekend before I hit it, if then.
psych is offline
post #2 of 11 Old 02-13-2013, 09:56 AM
87angler
1987 YJ Wrangler
i just got done doing both of these. i would run the jeep for a little while and get it warm. then park it and check on it in a couple of hours. if you see any drops around the end of the oil pan or on the exhaust then it could be the rear main seal. once you park it take a peak at the valve cover. if there is more oil then normal or if the cork gasket is squished out then theres your leak. i noticed that for while driving i could smell the valve cover leak because it was pooling up on my intake manifold and when i parked i could smell the rear main seal because it was dripping on the exhaust pipe. also my oil pressure was running really low because of the rear main seal. i just replaced both of them for the first time and they were not that bad. just make sure you follow a guide or manual (chillton) and dont forget the dish soap for what i assume was used for water displacement. good luck
[]lllll[]
87angler is offline
post #3 of 11 Old 02-13-2013, 09:57 AM
87angler
1987 YJ Wrangler
also they make really nice gaskets that are made out of a rubber or plastic with washers around the bolt holes so you cant tighten it down to much. really nice for the high oil leak areas
[]lllll[]
87angler is offline
post #4 of 11 Old 02-13-2013, 10:40 AM
Berniebikes
Definitely use a rubber gasket, shy away from the cork valve cover gaskets. Clean your head and bolts and bolt holes well. Torque the bolts to spec, and put a little drop of loctite (purple low strength or blue medium strength) to hold the bolts in place. Clean all the oil away from your engine and transmission and then see where, if any, you still have a leak. Some common places are the dipstict tube, the oil pressure sending unit, the input shaft of the transmission (which requires you to drop the tranny to fix), the oil pan gasket and lastly the rear main seal.
Berniebikes is offline
post #5 of 11 Old 02-13-2013, 11:09 AM
ZeroGravity
Simple to diagnose. Get some kind of de greaser (concentrated simple green actually works as good as most other degreasers) warm up the motor, spray the it down, let sit for a few minutes and clean off with water. Repeat until there is not more oil on the motor. Take it for a drive that will get your motor to normal operating temp, turn it off and check for leaking oil. If its a low pressure leak, like from the valve cover or oil pan, the leak is going to be below the highest level of oil you can see.
The oil pressure sending unit is also a common problem. It's located on the passenger side of the block behind the oil filter. If its leaking from there, you will notice a huge spray of oil covering the respective side of the engine compartment. The sending unit and brass fitting are cheap and easy to replace.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #6 of 11 Old 02-13-2013, 11:43 AM Thread Starter
psych
Thanks everyone. My first task is to degrease and inspect (to the best of my ability) this weekend. My friend said he felt it was more valve cover related due to the location of all the oil sprayed out everywhere and that I still have oil on the dipstick and good pressure...slow leak over time. I bought the jeep as is and it looks like its been leaking for quite a while. Most of the oil on the bottom side, by the exhaust, appears old and crusted. Guess we'll see!
psych is offline
post #7 of 11 Old 02-14-2013, 06:57 AM
Rproject
1987 YJ Wrangler
Are you still running the OEM valve cover? They're notorious for warping. If it is indeed your valve cover that's leaking, and it's the original, upgrading would likely be a wise idea.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 11 Old 02-14-2013, 07:37 AM Thread Starter
psych
Honestly, I have no idea. I have heard they are notorious for warping and was told if it's plastic, to upgrade to aluminum but I don't know if it's OEM or not. Any way of knowing?
psych is offline
post #9 of 11 Old 02-14-2013, 08:01 AM
Beachcruiser
1987 YJ Wrangler
Good idea to check your PCV system, too.
Mine would blow oil everywhere (even out the dipstick tube) when I first got it because the PO had a bad PVC valve in there.
probably out breaking stuff.
Beachcruiser is offline
post #10 of 11 Old 02-14-2013, 12:02 PM
seattle_yj
Check out this engine cleaning gun from harbor freight, it's the best 8 dollar tool I have bought. Hook it up to a compressor and a gallon of purple power and couple hours later your engine bay will be spotless. The plastic valve cover is t going to warp, use the blue felpro gasket if you only want to do it once. 12foot lbs only on those bolts.
seattle_yj is offline
post #11 of 11 Old 02-14-2013, 12:03 PM
seattle_yj
*not* going to warp. Sorry. It will not warp. cheers.
