Tachometer reading fluctuates - JeepForum.com
post #1 of 4 Old 04-29-2009, 12:24 PM Thread Starter
Sambox
I was driving down the interstate yesterday (65-75 mph) when I noticed that the tach would jump. I was cruising in 4th at about 2100 RPMs and it would jump up to 2400, then back down, the drop to 2000, then up again. I didn't notice any surging from the engine though.
Is there a sensor for the tach that could be going bad or is the flucuating a mechanical issue? Or do I not need to worry about it?
"Jeeps are the equivalent of barbies for men."-JaikYJ
1996 Cherokee XJ, All stock except for a Flow Master exhaust.........for now. He He.
Sambox is offline
post #2 of 4 Old 04-29-2009, 04:01 PM
dodger889
If you are still orginal the signal comes from the ecm drives the tach.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 4 Old 04-29-2009, 04:58 PM
Smash209
Smash209's Avatar
Did you recently replace the speakers with better, ie bigger magnet ones? Its the speaker next to the tach causing it to jump a little when the bass hits (ha... bass out of a 4x6)
Smash209 is offline
post #4 of 4 Old 04-29-2009, 05:36 PM Thread Starter
Sambox
Yeah, I'm all original and no, the speakers have not been changed...at least by me. This is the first time I've seen/noticed it happen.
So for it to fluctuate, the ECM is sending false signals? Is this indicating a bad ECM?
Sambox is offline
Tachometer help... rrisher YJ Wrangler Technical Forum 3 11-05-2008 10:52 AM
tachometer TravisR YJ Wrangler Technical Forum 8 04-09-2006 11:16 PM
tachometer RLSFANS1 YJ Wrangler Technical Forum 1 03-15-2006 07:32 PM
Tachometer volcom3375 YJ Wrangler Technical Forum 7 08-14-2005 02:09 PM
temp fluctuates new2jeep YJ Wrangler Technical Forum 14 06-04-2004 10:20 PM
