T&T Project CLY-J - JeepForum.com
post #1 of 40 Old 12-24-2012, 09:09 AM Thread Starter
TnTCustoms
TnTCustoms's Avatar
T&T Project CLY-J
Time for a T&T Customs project of a different sort.
After attempting to push the Low Wagon to its limits our GM, Rod, decided he wanted to build something that had a real "frame" underneath it .
The build plan.......
Begin with a 94' YJ, discard the YJ front clip and use a CJ front clip. Rod's been used to the cargo room of his XJ and has a couple boys so added space is also desired. Our solution for that is to add 15" between the door opening and the wheelwell making the tub the same length as an LJ while retaining a nice departure angle. The YJ frame will of course get stretched accordingly and suspension duties will be fullfilled by our YJ Rock-Tek coil conversion, with a few tweaks to account for the added length
Other specs include,
- T&T Fenders & Corners w/ 3" flares
- T&T Guardian sliders
- T&T Guardian front bumper
- T&T High Clearance rear XMBR
- T&T Cage
- Front HP Dana 44/60 Hybrid w/ 5.13's and 35 spline ARB & T&T axle truss
- Rear Ford Truck 8.8 w/ Moser 9" housing ends, 35 spline spool & 35 spline alloy shafts & T&T mounts
- 3.8 Atlas
- PSC Extreme Duty Hydraulic Assist
- 17" Trailready Beadlocks
- 39" Irok Radials
- Genright YJ EXT Tank
- Warn 9.5ti
Enough words....time for pics!
The YJ
Gutting the inside
- GO EQUIPPED !
TnTCustoms is offline
post #2 of 40 Old 12-24-2012, 09:10 AM Thread Starter
TnTCustoms
TnTCustoms's Avatar
Starting stripping it with a wire wheel and grinding disks....
- GO EQUIPPED !
post #3 of 40 Old 12-24-2012, 09:22 AM
gunshw301
Kewl
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #4 of 40 Old 12-24-2012, 09:22 AM
boxcar119
Very cool !! i'm in the process of a front clip change on an '87
Im looking forward to see how the fenders look with CJ grill
You may have a customer
Thanks for posting!!
boxcar119 is offline
post #5 of 40 Old 12-24-2012, 09:25 AM
'92 vegas YJ
Im in
'92 vegas YJ is offline
post #6 of 40 Old 12-24-2012, 09:39 AM
mtndrew
1983 CJ7
! Can't wait to see what you guys do
mtndrew is offline
post #7 of 40 Old 12-24-2012, 10:02 AM
sdotcarter
Ill be keeping an eyeball peeled on this one.
sdotcarter is offline
post #8 of 40 Old 12-24-2012, 10:06 AM
Carlos14
Finally a YJ. Well kinda.
Luck Favours The Prepared
Carlos14 is offline
post #9 of 40 Old 12-24-2012, 10:13 AM
DirtKar
I pledge allegiance.
DirtKar's Avatar
I'm in.
YJOTM JULY 2014
DirtKar is offline
post #10 of 40 Old 12-25-2012, 08:09 AM
AmmitOsiris
IM watching this
AmmitOsiris is offline
post #11 of 40 Old 12-25-2012, 06:00 PM
LilViper95
LilViper95's Avatar
I wanna see this! Too bad your ditching the square headlights!
04 Ram 2500 5.9L 24v HO Cummins
LilViper95 is offline
post #12 of 40 Old 01-07-2013, 01:06 PM Thread Starter
TnTCustoms
TnTCustoms's Avatar
Time to drill out some (some is an understatement) spot welds......
Bracing up the tub before cutting it in half
- GO EQUIPPED !
post #13 of 40 Old 01-08-2013, 09:49 AM
AZdEvilYJ
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #14 of 40 Old 01-16-2013, 11:25 AM Thread Starter
TnTCustoms
TnTCustoms's Avatar
The frame is rusted out so we'll get it stripped and its off to scrap. We've got one from a buddy out of Reno, NV that's rust free that we'll use instead.
Decided to take the tub and have it sandblasted, was worth every cent! We had an old welding table that'll work perfect for mocking the body up on while I repair rust spots and build the panels to reconnect the two halves.
Mocked up the corner blanks
Stay tuned as I start patching up some of the rust spots and put the tub back together.
- GO EQUIPPED !
post #15 of 40 Old 01-16-2013, 12:29 PM
NHfireLJ
NHfireLJ's Avatar
Jealous!!!!
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
jeep , stretch , t&t , YJ
