-   -   T&T Project CLY-J (http://www.jeepforum.com/forum/f12/t-t-project-cly-j-1453982/)
TnTCustoms 12-24-2012 10:09 AM
T&T Project CLY-J
Time for a T&T Customs project of a different sort. :thumbsup:
After attempting to push the Low Wagon to its limits our GM, Rod, decided he wanted to build something that had a real "frame" underneath it ;).
The build plan.......
Begin with a 94' YJ, discard the YJ front clip and use a CJ front clip. Rod's been used to the cargo room of his XJ and has a couple boys so added space is also desired. Our solution for that is to add 15" between the door opening and the wheelwell making the tub the same length as an LJ while retaining a nice departure angle. The YJ frame will of course get stretched accordingly and suspension duties will be fullfilled by our YJ Rock-Tek coil conversion, with a few tweaks to account for the added length :cool:
Other specs include,
- T&T Fenders & Corners w/ 3" flares
- T&T Guardian sliders
- T&T Guardian front bumper
- T&T High Clearance rear XMBR
- T&T Cage
- Front HP Dana 44/60 Hybrid w/ 5.13's and 35 spline ARB & T&T axle truss
- Rear Ford Truck 8.8 w/ Moser 9" housing ends, 35 spline spool & 35 spline alloy shafts & T&T mounts
- 3.8 Atlas
- PSC Extreme Duty Hydraulic Assist
- 17" Trailready Beadlocks
- 39" Irok Radials
- Genright YJ EXT Tank
- Warn 9.5ti
Enough words....time for pics!
The YJ
http://i711.photobucket.com/albums/w...pse82e7089.jpg
http://i711.photobucket.com/albums/w...ps30af0626.jpg
Gutting the inside
http://i711.photobucket.com/albums/w...psa4a34039.jpg
TnTCustoms 12-24-2012 10:10 AM
http://i711.photobucket.com/albums/w...ps2124089e.jpg
http://i711.photobucket.com/albums/w...ps83bb4103.jpg
Starting stripping it with a wire wheel and grinding disks....
http://i711.photobucket.com/albums/w...ps565b14c8.jpg
http://i711.photobucket.com/albums/w...psa640ca7e.jpg
gunshw301 12-24-2012 10:22 AM
Kewl
boxcar119 12-24-2012 10:22 AM
Very cool !! i'm in the process of a front clip change on an '87
Im looking forward to see how the fenders look with CJ grill
You may have a customer
Thanks for posting!!
'92 vegas YJ 12-24-2012 10:25 AM
Im in
mtndrew 12-24-2012 10:39 AM
! Can't wait to see what you guys do
sdotcarter 12-24-2012 11:02 AM
Ill be keeping an eyeball peeled on this one.
Carlos14 12-24-2012 11:06 AM
Finally a YJ. Well kinda.
DirtKar 12-24-2012 11:13 AM
I'm in.
AmmitOsiris 12-25-2012 09:09 AM
IM watching this
LilViper95 12-25-2012 07:00 PM
I wanna see this! Too bad your ditching the square headlights!
TnTCustoms 01-07-2013 02:06 PM
Time to drill out some (some is an understatement) spot welds......
http://i711.photobucket.com/albums/w...ps6e31dc3a.jpg
http://i711.photobucket.com/albums/w...ps25c8050f.jpg
Bracing up the tub before cutting it in half :D
http://i711.photobucket.com/albums/w...ps88d61395.jpg
http://i711.photobucket.com/albums/w...ps9779f065.jpg
http://i711.photobucket.com/albums/w...psdd5ddb2b.jpg
AZdEvilYJ 01-08-2013 10:49 AM
:PopCorn:
TnTCustoms 01-16-2013 12:25 PM
The frame is rusted out so we'll get it stripped and its off to scrap. We've got one from a buddy out of Reno, NV that's rust free that we'll use instead.
http://i711.photobucket.com/albums/w...psca40f93a.jpg
Decided to take the tub and have it sandblasted, was worth every cent! We had an old welding table that'll work perfect for mocking the body up on while I repair rust spots and build the panels to reconnect the two halves.
http://i711.photobucket.com/albums/w...ps0b5ef079.jpg
Mocked up the corner blanks :drool:
http://i711.photobucket.com/albums/w...psd130909d.jpg
Stay tuned as I start patching up some of the rust spots and put the tub back together.
NHfireLJ 01-16-2013 01:29 PM
1404 Attachment(s)
Jealous!!!!
The time now is 09:09 AM.
