T-case symptoms? - JeepForum.com
post #1 of 15 Old 02-13-2009, 08:41 PM Thread Starter
tuckinauster
tuckinauster's Avatar
T-case symptoms?
My POS just broke down on me for the 6th or 7th time . I'm thinking I have a stretched chain in my 231. Whenever its in gear and moving I'm getting a constant ratcheting sound coming from the floor boards. The transmission shifts fine and all the gears work fine. It shifts into 4wd hi and low normally as well. The other thing I noticed is there is ATF from the t-case in the tranny, and gear oil from the trans in the t-case. It was also leaking ATF pretty bad, but I couldn't locate exactly where from. When I checked the fluids, the trans was down about a quart, give or take some. I topped it and the t-case off, drove the jeep around a bit, and noticed no change in the noise.
I got it towed to my gf's place which is 270 miles from my tools, so I'll do the best I can with what I have, but I'm probably gonna have to have it trailered back up to my place... Let me know what you guys think, I appreciate it!
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #2 of 15 Old 02-14-2009, 09:37 AM Thread Starter
tuckinauster
bump... no ideas???
post #3 of 15 Old 02-14-2009, 10:25 AM
osburn
osburn's Avatar
The tcase and tranny are sealed units. I can't imagine how you're getting ATF into the tranny. All I can say is you've obviously got to pull both and see what the heck is going on. Not much anyone here can do for you except show up for the Jeepfest.
Matt Osburn
Score 1032
osburn is offline
post #4 of 15 Old 02-14-2009, 11:02 AM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
If the seals are gone the tranny can leak into the tcase. Mine did this.
The skipping sound could be the tcase chain slipping OR if you're in 4wd and you have a vac disconnect, the axle could be letting go.
I'm not necessarily a dim kind of guy (despite what my idiot friends may say... ;-) and I actually swapped my tcase for a u-pick only to discover that my front "locked disconnect" was letting go. Oh well, I wanted to change that tcase anyhow!
Good luck.
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #5 of 15 Old 02-14-2009, 11:49 AM Thread Starter
tuckinauster
My rig has a posi lock, so no vac disconnect to worry about. I messed with it a little more this morning, and noticed that it rattles even while idling with the clutch engaged. If you push the clutch in, the noise goes away. This is confirming my stretched chain suspicions... My other question is, can I remove the chain and still be able to drive the rig home, or is this a no go? I've never been inside a 231, so I'm kinda vague on the operation.
post #6 of 15 Old 02-14-2009, 12:06 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Still too many possibilities to be sure.
You should be able to shift the tcase into 2wd and drive the YJ without the chain skipping and be able to feel it.
I've had one chain stretch in a tcase to where it skipped under load in 4wd. I had another where I could hear the chain rub on the case but no shudders. If the vehicle was only driven in 2wd you couldn't feel the chain skip. These are just my experiences. Maybe something else is wrong.
post #7 of 15 Old 02-14-2009, 12:19 PM Thread Starter
tuckinauster
Well, I convinced the old man to bring the dually down so we can drag the POS back home. I'll try to get it torn apart early this week, and I'll keep you guys updated on what I find out. I'm keeping my fingers crossed that it'll be a simple and cheap repair, but considering my luck I'll be buying a new tcase in the near future.
post #8 of 15 Old 02-14-2009, 12:39 PM
No_Return
The T-Case on my XJ sounded like this Just before it tore a hole in the bottom. No really it did... trashed the case.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #9 of 15 Old 02-14-2009, 02:52 PM Thread Starter
tuckinauster
This is why I'm not gonna risk driving it home... I had a Dakota with a NP231D that broke in 3, yes 3, complete pieces after some thrashing...
post #10 of 15 Old 02-25-2009, 10:18 PM Thread Starter
tuckinauster
Update:
I got the rig home ok, and tore the t-case out last week, and I finally got around to tearing into the t-case yesterday. I've been procrastinating a bit about the project a little ... Anyway, I got it all taken apart and noticed that the rear output shaft main bearing went boom. The plasitc bearing retainer looked like it went through a wood chipper, and the ball bearings were just sort of there...
This was causing the main shaft to wobble enough to kill both the t-case front seal, and the transmissons rear seal. It also marked up one edge of the front output shafts chain sprocket a bit.
Last night I got on Q-tec and ordered an overhaul kit with all new bearings and seals, as well as a new tranny seal. I still need to pick up some new u-joints, and I'll probably throw on a new muffler while I have it all apart.
If I remember, I'll take some pictures of the bad bearing, and of the re-assembly.
post #11 of 15 Old 02-25-2009, 10:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Good time for a SYE kit, huh?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #12 of 15 Old 02-25-2009, 10:23 PM Thread Starter
tuckinauster
Max
I wish... I just don't have the bones to drop on one right now. At least I'll be familar with the t-case when I do get one.
post #13 of 15 Old 02-25-2009, 10:31 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I hear ya! I went & looked at an $800 ZJ today to buy as a "spare/project Jeep" and just couldn't bring myself to pull the trigger.
As if I need a 4th Jeep, or another project!
Max
Mean Max is offline
post #14 of 15 Old 02-25-2009, 10:35 PM
jgillespie
i agree, it seems to be the chain.
man, the SYE would be awesome to do while down under there working...if i had the means, i would put one in now, before my lift so i would already have it!
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
Last edited by jgillespie; 02-25-2009 at 10:35 PM. Reason: struggling with my english in the current state of mind
jgillespie is offline
post #15 of 15 Old 02-25-2009, 10:57 PM Thread Starter
tuckinauster
The chain is actually in good shape. Before I took it off it seemed to have good tension, after it was off I inspected it carefully, and it looks to be in pretty decent shape.
Just to be safe though, does anyone know how much chain deflection there should be when its installed??? I checked my overhaul manual, and it doesn't mention anything about the tension.
Symptoms of a clogged CAT badassjeep04 TJ Wrangler Technical Forum 14 09-22-2009 10:52 AM
U-Joint symptoms Reverb YJ Wrangler Technical Forum 5 05-05-2009 03:11 PM
Here are some symptoms.... ncmva YJ Wrangler Technical Forum 9 04-23-2007 08:28 PM
What are some bad tranny symptoms? Bot YJ Wrangler Technical Forum 4 11-01-2005 05:44 AM
Anyone have these symptoms? 97sahara TJ Wrangler Technical Forum 7 01-03-2005 03:26 PM
