T Case Question - JeepForum.com
post #1 of 7 Old 12-16-2011, 11:49 PM Thread Starter
cevans87
1992 XJ Cherokee
T Case Question
So I know have a xj 231 in my yj that is attatched to an aw4 ...
when i try to shift on the fly from 2hi to 4hi i get a bad gringing noise and haven't been able to engage...
if i stop completely... shifts fine
if im in 4hi and shift on the fly to 2hi shifts fine...
i still have the cad system on the dana 30...
any info would be appreciated
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #2 of 7 Old 12-17-2011, 06:07 AM
kloppk
I suspect the XJ tcase doesn't have the synchro in it that a YJ tcase would.
In non-vacuum disconnect jeeps the fron drive shaft is always spinning so the tcase doesn't need the synchro.
In YJ's with the vacuum disconnect axle the tcase needs to have the synchro in it to spin up the front driveshaft when you shift from 2HI to 4HI. Without the synchro in a YJ it's going to grind....
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 7 Old 12-17-2011, 06:24 AM
Mark05059
not sure what your talking about kloppk. My cherokee I could go in and out of 4x without any problems on the fly when I had my XJ.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 7 Old 12-17-2011, 08:29 AM
kloppk
YJ's use the CAD axle disconnect. The tcase's in YJ's have a synchro in them to spin up the front driveshaft to avoid gear clash.
Earlier XJ's that had the same CAD axle disconnect used the same synchro system in the tcase.
Later XJ's did away with the CAD axle disconnect. The synchro was no longer needed since the front driveshaft is always spinning with a non-CAD axle. The same is true for all TJ's.
I suspect the OP has the later XJ tcase without the synchro in it. The tcase is trying to engage but without the synchro the teeth are not synchronized when the mode fork tries to engage the non-spinning front drivshaft.
I agree, all stock XJ's, YJ's and TJ's will shift on the fly with the factory (correct) tcase installed.
CAD axle YJ's & XJ's requires the tcase with a synchro
Non-CAD axle XJ's do not require a tcase with the synchro.
Please refer to the parts diagrams for tcases in CAD & non-CAD Jeeps.
You'll see the synchro in tcase in jeeps with the CAD axle.
Baystate Jeepers
Deep Woods Extreme
kloppk is offline
post #5 of 7 Old 12-17-2011, 12:23 PM
Apollo12227
Some XJ tcases came with a synchro some didn't. His doesn't seem to have one.
http://www.jeepforum.com/forum/f12/w...ft-fly-949926/
Apollo12227 is offline
post #6 of 7 Old 12-17-2011, 02:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds like you need a one piece conversion or just to lock the collar on the two piece system over and make sure your driveline is balanced. That'll solve your problem.
Luck Favours The Prepared
Anticanman is offline
post #7 of 7 Old 12-17-2011, 04:40 PM Thread Starter
cevans87
1992 XJ Cherokee
sounds like a winner, thats what i was leaning towards was that the cad system played a big role and that i didn't have the synchro... but i needed it confirmed... kinda like tasking someone to look at the same picture to see if they see something you don't... thanks guys... will be swapping to dana 60's soon so untill then i just won't shift on the fly
cevans87 is offline
T case question jborin0311 Wrangler General Discussion 1 08-16-2010 08:20 AM
NP231C/J transfer case - Case Question Kelvinator YJ Wrangler Technical Forum 5 09-28-2009 11:35 AM
231 transfer case question cherokee case in a tj? 472cid TJ Wrangler Technical Forum 5 06-11-2009 09:39 PM
ZJ guy with a 231 T-case question. 5.9 ANDY YJ Wrangler Technical Forum 4 08-20-2007 01:38 AM
T-case question - 231 phattdraggon YJ Wrangler Technical Forum 18 01-26-2005 01:24 PM
