Quantcast T-Case Pops Loudly - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > T-Case Pops Loudly
Old 02-05-2007, 07:28 PM   #1
metal_kid17
T-Case Pops Loudly
So I just put my Posi-Lok on saturday and things were going great. The jeep was gettin through anywhere I put it. I was messing around earlier and put it in 4Lo and took off and heard a loud pop. Then it felt like my front axle disengaged again. I got underneath and checked all my lines for the posi-lok, and everything seemed to be fine with that. Anyone have any idea what this actually is, because its really p*****g me off. Any help would be appreciated.
metal_kid17 is offline   Reply With Quote
Old 02-05-2007, 07:36 PM   #2
kloppk
Posilock out of adjustement?
Stretched/worn tcase chain?
Broken tcase chain?
Broken axleshaft?
Tcase not fully engaged?
kloppk is offline   Reply With Quote
Old 02-06-2007, 01:27 PM   #3
metal_kid17
The Posi-Lok seems to be adjusted perfectly. I was looking into it a little bit online last night and found that the chain will stretch and cause it to mess up sometimes. Whats weird tho is that I drove it in 4Lo for about 30 mins. today and everything seemed to be fine. Last night when I did it it took about 10 mins and it went out. I think I might : A) Rebuild the T-Case or B) Just buy another NP231.
Old 02-09-2007, 11:48 PM   #4
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
rebuild yor t-case you can get a wide chain kit from JB conversions for about the price of another t-case and it will be stronger
JJ-4 is offline   Reply With Quote
Old 03-16-2007, 08:05 PM   #5
90XJGuy
Hey i got the same problem with my XJ, the posi lok will disengage by popping. I noticed that when it's engaged in heavy snow it's fine but on lite snow roads like today it's bad... My front end or the T-case has a really weird whining sound and it gets gradually louder at higher speedsthen pop(more like bang), nothing over 30-35 mph will keep this front axle engaged. I need to figure this out soon it's driving me nutz
Edelbrock SDT Muffler,Custom Air Intake,31x10.5 Tires on Black Cragar Soft 8 15x9's,1.75 Teraflex Shackles and HD Leaf Springs,Surco Safari Roof Rack,Walmart Light Bar,Pioneer Deck,Posi-lok front kit, welded rear end. Corba CB radio. Doorless when playing also
Rough country 3" AAL
1990 Jeep XJ[url=http://photobucket.com/albums/y239/caddydeville/Jeep/?action=view&slideshow=true] My Jeep[/url]
90XJGuy is offline   Reply With Quote
Old 03-16-2007, 10:57 PM   #6
jeepin92yj
mine did the same thing for awhile but i found it out to be the front u-joints. at the time i thought it was the tcase as well
[SIZE="5"][B]-Black Betty-[/B][/SIZE]
[SIZE="1"]4.0L 5spd[/SIZE]
[SIZE="1"]Rubicon 4" kit (5" of total lift)[/SIZE]
[SIZE="1"]5/8 Boomerang Shackles[/SIZE]
[SIZE="1"]2" body lift[/SIZE]
[SIZE="1"]35x12.50r15 Mickey Thompson MTZs[/SIZE]
[SIZE="1"]Ford 8.8 Rear with Rugged Ridge diff. cover [/SIZE]
[SIZE="1"]4.88s[/SIZE]
[SIZE="1"]Detroit locker in rear and Lock Right up front[/SIZE]
jeepin92yj is offline   Reply With Quote
Old 03-17-2007, 12:34 AM   #7
90XJGuy
hmmm..... yeah i've been meaning to try that first. After fartin around in this wonderful snow storm here in MA, The 4wd just gets worse everytime. now i pretty much will leave it in 2wd unless i need to takeoff from a stop then i throw it in 4wd. this sucks. I spend 200 bucks on a system ( bought the cast iron fork too) and it's craps out on me after one year this week
Oh another thing does the knob button on your posilok rotate left and right and gets tighter or looser??? mine does if you turn the black ring or base under the red button.this is when engaged or not engaged.....
Old 03-17-2007, 10:19 AM   #8
olyjeep
2011 JK Wrangler
posi lok knob
I just bought a YJ that has a posi lok installed (and this is new to me) I never had a Jeep with one before.
As far as I know, you loosen it a little bit to the left, push the button in the middle, then pull it out. This turns on my 4wd light then I pull the t case lever into 4 hi. Then I was not sure if I had to twist the posi lok knob to again to lock it in 4wd. And if I am supposed to twist it... left or right?
I was driving around last night and I had the same popping you were describing. I think I was doing something wrong with engaging the posi lok. Only happened twice but it still had me concerned.
2011 Unlimited
Auto, 2.5 Teraflex BB
33" Duratracs
olyjeep is offline   Reply With Quote
Old 03-17-2007, 01:26 PM   #9
yesterdaylight
this sound is most likely your transfer case chain. take care of it before the chain derails, jams, locks your drivetrain, and blows your tranny. as mine did. That's the worst case scenario but check it out. A t-case chain is around $90 from napa. -ian
Green Jeep Club Member #172
Low Output 4 Cylinder Jeep Club Member # 23
Green 1995 4 Banger
If only my pocket was as green as my Jeep :D
yesterdaylight is offline   Reply With Quote
Glock Forum
