T-case lowering kit - JeepForum.com
post #1 of 8 Old 06-15-2003, 06:30 PM Thread Starter
19OlllllllO41
19OlllllllO41's Avatar
T-case lowering kit
Im going to be putting on a 2 in sus lift on my jeep this week. I know the kit didnt come with a t-case lowering kit, but im sure im going to need one for the time being to keep the vibs out until i can afford a sye maybe someitme down the road. The question i have is, can i just use some pieces of 1in steel square tubing and some longer bolts that i have layin around for the lowering kit? kindof modeled after the skyjacker lowering kit that they rape you like $40 for? anyone ever do theirs this money saving way? or is there somehting special bout the skyjacker set up that i dont know about?
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #2 of 8 Old 06-15-2003, 07:13 PM
Moxley
Moxley's Avatar
2017 JK Wrangler
You certainly can. A lot of kits are basically nothing but that [1" spacers with 1 1/4" longer bolts]. I went with the $30 skyjacker kit because it's red and matches my Jeep. I am such a loser! Good luck with your lift....
Doug
Moxley is offline
post #3 of 8 Old 06-15-2003, 08:49 PM Thread Starter
19OlllllllO41
sweet, thanks moxley. yeah i really considered just buyin the skyjacker lowering kit cause like you said the red matches good and looks cool, im just to strapped for cash right now so maybe some rustoleum will have to do! thanks again for the info!
The Present:
'04 WJ
'46 CJ2A
The Past:
post #4 of 8 Old 06-15-2003, 09:11 PM
Atari423
Atari423's Avatar
just to add to that... a question of totally curiousity... is 2inch drop too much?
95' Jeep Cherokee, 4.0, 3.5'' lift, 31x10.50x15 crawler rims.
Atari423 is offline
post #5 of 8 Old 06-16-2003, 08:08 AM
Birdawg
Birdawg's Avatar
My Rubicon 2 1/2" lift comes with a 1" transfer case drop kit, if that helps.
Peter
1992 YJ 4.0 Liter HO I6
Sitting on a Rock in the Bay
Air Restrictor & Chicken Bones Gone,20 Gal.Gas Tank :) Audiovox CD Sound Bar, Front Tow Hooks. Hard & Soft
Tops. 31" x 10 1/2" x 15" Coopers
Sumer Projects:2 1/2" Rubicon Express.(Done) New Metalic Paint.(Done)
31" Tires (Done), Bed Liner. Dome Light for Soft Top
Blue Jeep Member #15
Birdawg is offline
post #6 of 8 Old 06-16-2003, 08:19 AM
Moxley
Moxley's Avatar
2017 JK Wrangler
I haven't seen anything more than 1 1/4" drop so I would be scared to go a full 2". Maybe someone else out there would know?
Doug
Moxley is offline
post #7 of 8 Old 06-16-2003, 08:53 AM
Gper4life
I guess it all depends on your fan hitting your radiator with two inches of drop. If you wanted to get a jack and while your skid plate is down just the transfer case at two inches and look at the fan. You might be able to get away with it with an electric fan though. I gotta pull my transfer case out in a day or two so I'll let you guys know about the two inch drop.
89 YJ upgraded with 95 Chevy LT1 small block, NV4500 5spd, tera low 231 SYE, Custom built crossmembers and skids, 2003 Corvette Electron Blue paint, 3 inch custom spring lift with 2 inch shackles, 2 inch body lift, locked 8.8 with discs, 4:10's and 35's, spray lined tub, and a few other unmentionables
Gper4life is offline
post #8 of 8 Old 06-16-2003, 09:08 AM
bigsteve3184
bigsteve3184's Avatar
I have a skyjacker t-case drop for sale.....make an offer.
95 YJ 2.5L
SOA/2" BDS Springs/ 1" body
D44 ARB/Ford 9" Detroit Locker/5.13/ 36's
www.novajeepers.com
bigsteve3184 is offline
Do I need a...???? (t-case lowering kit) WillRyan TJ Wrangler Technical Forum 9 03-04-2008 03:14 AM
SYE/T-case lowering kit levi333 YJ Wrangler Technical Forum 1 06-24-2006 11:19 PM
T-case lowering dono man YJ Wrangler Technical Forum 5 04-08-2006 09:58 AM
T-case Lowering nzjnyf TJ Wrangler Technical Forum 15 05-14-2003 06:59 AM
no t-case lowering kit nomad6 TJ Wrangler Technical Forum 2 05-02-2003 02:06 PM
