T-case knocking - JeepForum.com
post #1 of 4 Old 08-07-2013, 11:39 AM Thread Starter
Jdawg319
T-case knocking
Whenever i drive my 93 renegade it makes a kind of knocking/ticking noise. The noise is faster the faster i go,and same slow wise. At first i thought it was a U-joint but they all seem fine. Then i decided to spin my front drive shaft back and forth by hand really fast and it sounded like the same noise. Does anyone have any ideas of what it is exactly? Or if its a big deal at all?
Jdawg319 is offline
post #2 of 4 Old 08-07-2013, 11:56 AM
XJ93
Does the noise change when you engage 4wd? Is it coming from the t-case? I suspect a loose chain or the shift forks are getting worn and rubbing.
XJ93 is offline
post #3 of 4 Old 08-07-2013, 01:03 PM Thread Starter
Jdawg319
Yes, Yes, i just went outside and put it in 4wd drove it up and down the street a couple times and no ticking whatsoever. What would that be then?
Jdawg319 is offline
post #4 of 4 Old 08-07-2013, 02:07 PM
XJ93
Probably a shift fork. Try adjusting the t-case linkage first.
XJ93 is offline
jeep yj , ticking noise , transfer case
