t case fluid capacity? - JeepForum.com
post #1 of 10 Old 02-12-2013, 05:32 PM Thread Starter
AaronMitchell
i have an 87 wrangler i6 5 speed.
changed all the fluids today but confused about the t-case
i bought 2 quarts because i read it takes 2.2 pints,
but even after putting those 2 and another 1/2 i has lying around it still isnt coming out the fill port.
Is it not like everything else where you fill until it pours out?
AaronMitchell is offline
post #2 of 10 Old 02-12-2013, 06:36 PM
jokerchief462
It had to go somewhere!!! I understand the frustration but I have never seen more than 2 quarts in a dry T-Case (NP-231J).
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 10 Old 02-12-2013, 06:37 PM
Hghgrad
I think I was only able to get like 1 3/4 qts in mine today. It was completely apart and drained prior to this.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #4 of 10 Old 02-12-2013, 06:57 PM
YJBIGRED
Does it have a Puegot/NP206 or a np231? 206 didnt take much in mine
YJBIGRED is offline
post #5 of 10 Old 02-12-2013, 10:38 PM Thread Starter
AaronMitchell
It has the puegot transmission but Idk how to check which tcase...
It def never got high enough to reach the fill hole with my finger with the 2.5quarts but I did notice a rather large puddle of atf under my jeep before I left work work so its meaning out somewhere but didn't have time to check so I didn't drive it.
Is there an overfull drain or something that would let that extra quart or so out
post #6 of 10 Old 02-13-2013, 08:21 AM Thread Starter
AaronMitchell
Puddle is much larger and its still dripping
Can't see where its leaking from so either a damaged tcase or is there possibly some kind of overflow that's letting the extra out drops at a time
post #7 of 10 Old 02-16-2013, 06:22 AM Thread Starter
AaronMitchell
It appears the gasket/seal on the back side of the tcase is leaking, but I still don't know if I need to measure fluid out to 2.2pints or of I should fill until it comes out the fill plug
post #8 of 10 Old 02-16-2013, 06:48 AM
insaneinline
You should just fill it and let it run out until it stops but make sure your on a level surface
insaneinline is offline
post #9 of 10 Old 02-16-2013, 10:34 AM Thread Starter
AaronMitchell
Yeah I have a paved driveway, its just going to take several quarts more than the 2.2 pi ts
post #10 of 10 Old 02-16-2013, 11:29 AM
roadyrob
1987 YJ Wrangler
the NP207 transfercase is used in the 87. I tried finding the capacity for you but all I found was when the case is used in a chevy it holds 4.3 pts. not sure if its the same when in a jeep.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
