T-case chain - JeepForum.com
post #1 of 23 Old 11-19-2011, 10:57 AM Thread Starter
media88
T-case chain
so i recently just put my new winch on to get ready for rausch creek, then my t case chain starts slipping! yes have used the search function and yes have watched a couple videos. its about 50/50 to leave it in the jeep and just split the case or not. this would make things much easier if i could! what are your opinions everything operates fine and it barely skips once in a while just wann get it done. or if you could post succesful links that maybe have not seen that would be greatly appreciated! anyone near delaware county pa wanna show me? that would be even better! thanks
1994 JEEP WRANGLER YJ, 4.0 AX-15, DANA 30/35 STOCK GEARS, 4 INCH SKY JACKER LIFT KIT, T-CASE DROP, 32X11.50 DUNLOP MUD ROVERS ON BLACK RIMS, CHROME EVERYWHERE, CLEAR CORNERS, WHITE GAUGES, RHINO LINED INTERIOR,FRAME AND TUB, FRESH MOTOR CLUTCH AND TRANS, 236K ON THE BODY!!!
media88 is offline
post #2 of 23 Old 11-19-2011, 11:24 AM
Karma
HI media,
How do you know the chain is slipping?
If it is, hopefully it is not causing more damage. I think you should replace and repair mucho pronto if slippage is actually the problem. It's not that hard. If not, find out where the problem is and repair. It's not smart to let problems linger.
Sparky
Karma is offline
post #3 of 23 Old 11-19-2011, 11:53 AM
AnonymousD
Yea if its slipping, the its gonna break something soon enough. Change it out. I swapped mine out when I did my SYE and it was easy. Especially since I already had everything out. They can be had for around $80 on eBay.
AnonymousD is offline
post #4 of 23 Old 11-19-2011, 01:08 PM Thread Starter
media88
did you do it in the vehicle or while it was out?
media88 is offline
post #5 of 23 Old 11-19-2011, 01:25 PM
dillonjm
2013 WK
Its easy to do while its still in the vehicle, although it doesn't take very much effort to take it out and do it on a workbench. Only a couple extra bolts.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #6 of 23 Old 11-19-2011, 02:24 PM Thread Starter
media88
less bolts the better lol how were you trans mount bolts and the skidplate its the only thing im scared of
media88 is offline
post #7 of 23 Old 11-19-2011, 02:45 PM
gbeltran
I did mine while it was in the vehicle. It helps to have air tools, especially for taking the nut off the front yoke. That had to come off so the assembly was loose enough to remove the old chain and get the new one on. Took maybe an hour.
gbeltran is offline
post #8 of 23 Old 11-19-2011, 04:54 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Go ahead and install the "upgrade" from alloyusa and let us know how it goes. It'll help us both out...
Luck Favours The Prepared
Anticanman is offline
post #9 of 23 Old 11-19-2011, 05:04 PM
jsawduste
2006 YJ Wrangler
Do it right.
Take it out and fix/replace what needs to be done. Seals are a given. The mounts for the trans ought to be done.
Your gonna spend all the time and money to go to RC and then blow it when you junk (slang for Jeep BTW) craps out `cause you did`nt do what should have been done.
jsawduste is offline
post #10 of 23 Old 11-19-2011, 09:04 PM Thread Starter
media88
i actually just saw a full rebuilt on ebay for 300 with a warranty? ever see that? and i plan on a new trans mount just didnt really wanna break down the t case im confident on doing the chain just not much further!
media88 is offline
post #11 of 23 Old 11-19-2011, 09:14 PM Thread Starter
media88
scratch that not getting the ebay one lol i mean the t case feels fine minus the chain and it barely slips should i do a full rebuild or no? i would like to keep the costs down figuring i just dumped a posi lock and a winch in it.
media88 is offline
post #12 of 23 Old 11-20-2011, 05:29 AM
Karma
HI media,
I asked this in the first reply in this thread. You never answered.
HOW DO YOU KNOW THAT THE CHAIN IS "SLIPPING"?
I've never heard of this. I've heard of breaking, or slapping but not slipping.
Sparky
Karma is offline
post #13 of 23 Old 11-20-2011, 06:39 AM
Louie4
Originally Posted by Karma View Post
HI media,
Sparky
I'm wondering this too. I'm not doubting you have a problem but I've never heard of a chain slipping. If it did, I'd imagine a loud "pop" when you put power to wheels in 4WD.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #14 of 23 Old 11-20-2011, 07:42 AM
4.7stroker
Oh trust me the chain can slip. It gives a nasty Kerchunk when it does. It will only do this on 4x4 when under load.
If you have limited time just change the chain in the vehicle but as mentioned above it is not hard to remove the tcase and do it on a bench.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #15 of 23 Old 11-20-2011, 08:03 AM Thread Starter
media88
When its under load it slips and pops and at low rpm the chain slaps the case or so I think lol
media88 is offline
Do I need a new chain in my t-case? AnonymousD YJ Wrangler Technical Forum 11 11-03-2010 04:43 PM
Transfer Case Chain? yjdrvr YJ Wrangler Technical Forum 1 03-30-2008 10:24 PM
Trying to take off T/case chain brockenshire YJ Wrangler Technical Forum 22 09-21-2007 10:17 PM
which transfer case chain? GringoLoco TJ Wrangler Technical Forum 3 02-18-2007 04:00 AM
transfer case chain???? chazzy YJ Wrangler Technical Forum 1 04-23-2005 01:07 PM
