Synchros shot, make things worse by continuing to use?
#1 | |
Hello all, first post here,
I'm considering the purchase of a '90 Wrangler, SE I believe with a 5 spd. Synchros for 3 and 4 are gone. Double clutching helps on the upshifts, but I couldn't in my short test drive, get a heel toe to actually stick without grinding. With that said, knowing that it has the problem, will I make it worse by continuing to drive on the otherwise worn out tranny, or will it just end up being annoying. I use to drive a Nissan pickup with 300K+ that had the same problem and didn't seem to be effected reliability wise, but whats your experience? Thanks, Chris
#2 |
I maybe wrong but that may have the Peugot tranny init. If so the only thing that won't do anymore damage to it is take it out and set it in the corner of the garage. Eventually the gears themselves will go and or it will start popping out of gear alot if you keep running it.
89' YJ Larado 4.0L,AX15 01' Grand Cherokee 4.0L Check my Gallery for pics. My Rebuild Thread Take a minute and fill out your profile, Please |
#3 |
last of the peugots were mid 89,,,,,if its an se you have an ax-5,,,
#4 |
Great. The person selling said engine was replaced with a 95, I wonder (doubt) the trans was as well. In any case,...
How much is a rebuild/good running used example? Thanks, Chris |
#5 |
i have an ax5 that had the 1st and 2nd synchros worn. had to drive away in 3rd at times. got a "transparts" overhaul kit from e-bay for about 120$, took the tranny out myself, took it to my mechanic, he replaced everything and helped me put it back in, and installed a new clutch, all for 250$. i recommend it
if the synchros are all there is to it, i wouldn't be to worried about it. i drove mine 6 months before repairing it..
'95 2.5l red YJ. 35"BFG MTs on 4.5"SKYJACKER lift+ 5/8"Boomerangs, overhauled AX5 (still sucks) smittybilt flares, bestop softtop and doors, double core aluminum radiator with Flexalite fan, new brakes allround, all poly bushings, armour www.4x4build.com |
#6 |
If it's a 4 cylinder it's an AX5. If it's a 6 cylinder, it's an AX15. The Peugeot went away after March 1989. If it's hard to shift into gear, it is possible to bend a shift rail.
#7 |
To answer the original question
If it were mine, i would get it taken care of as soon as possible. You risk chipping teeth on your gears if you have to grind it into everygear. That will just add to the bill to rebuild it later on. Plus double clutching can get real old quick |
#8 | |
Hope I didn't get overly hosed, but I needed something done quick. DD'er and all you know... :
I got a Jeep, it's lifted and it's got crap bolted to it. Color by Rattle-Can. LO Jeep Club #111 [and not proud of it] Red Jeep Club #MC399 |
#9 |
i think you did get hosed, i got my ax-15 rebuilt and installed for $375
#10 |
Not sure what I'll be doing. I tried to start the Jeep this morning and I'm pretty sure the battery is dead. Need to replace it and see what to do from there.
This is somewhat of a family use second car. Winter driving and something for my wife to learn stick on so she can drive my car. I think if I did anything I'm going to go with a rebuild of the original eventually (next year?), first I need to figure out what the original engine/tranny was, and what the current one is. Thanks, Chris |
#11 | |
I didn't pay that much for my entire jeep...
4.0L Ford 8.8 4.56 lsd D30 SOA, 4.56 BFG 35 X 12.50 AT's Ebay Bushwacker knock-off TJ flares - tuffy security console. Stainless steel braided brake lines skyjacker pitman arm skyjacker hydros Buy my unit bearings! http://www.jeepforum.com/forum/showthread.php?t=533752 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
