SYE Who has some Info?? - JeepForum.com
post #1 of 5 Old 03-26-2002, 10:01 PM Thread Starter
jeepinarkansas
1982 CJ8
been having some vibrations on my recent install of a 3" rough country suspension lift. Wanted to know what you guys/gals thought. Should I drop the cash and invest in a SYE and a near rear driveshaft, or should I go from a 6 degree shim on the rear springs and go to an 8 or 10 degree shim in an attempt to skip the sye. Everyone I have talked to says the angle on my drive shaft is not that bad, but agree that it is the root of my problems. Any help would be appreciated. I did install the transfer lower brackets if that helps.
Jake
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #2 of 5 Old 03-27-2002, 10:46 AM
V8wrangler_idaho
i have a rough country lift to. did the same thing. The shims that are in there are to much. You should go with the 2.5 angle shims. if that dosen;t stop the vibrations. go with the cv joint drive shaft and change out the output shaft of the tranfer case.
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #3 of 5 Old 03-27-2002, 10:50 AM
osburn
osburn's Avatar
You have too much shim already is what sounds like your problem. When you're talking about a standard driveshaft with one u-joint at each end (non-CV), the tcase yoke and the pinion yoke need to be parallel. So no matter how much lift you put in, the rule is the same. By dropping your tcase, you only changed the angle of your output yoke about 2.5 degrees. So you compensate for that by putting in 2.5 degree shims on the rear perch to rotate the pinion up accordingly. When I ran a CV shaft with a 3.5" and 4" lift, I used 6 degree shims. A CV shaft is a different set of rules. Why did you use 6 degree shims? I would bet if you simply changed to 2.5 degree shims, your problem would be eliminated. Then again, a SYE with a CV shaft is certainly a better solution.
Matt Osburn
Score 1032
osburn is offline
post #4 of 5 Old 03-27-2002, 11:18 AM Thread Starter
jeepinarkansas
1982 CJ8
Thanks for the advice guys. The reason for the 6 degree shim is that is what came on hte spring assembly. Hey Idaho, how about that hardtop?
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
post #5 of 5 Old 03-27-2002, 07:03 PM
osburn
osburn's Avatar
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by jeepinarkansas:
<strong>Thanks for the advice guys. The reason for the 6 degree shim is that is what came on hte spring assembly. Hey Idaho, how about that hardtop?</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Well, if you do try the 2.5 degree shim and it works. I think both of you should get back with those guys and let them know they're sending the wrong shims with the kit. I wonder how many others out there didn't know and thought the only fix was an SYE. I mean, 6 degrees is perfect for an SYE and 3-4" of lift. Seems almost suspicious don't it?
Matt Osburn
Score 1032
osburn is offline
need lift info & regearing info stuart2410 JK Wrangler Technical Forum 3 01-18-2009 10:28 AM
need info on cps on 89 i6 lee95yj YJ Wrangler Technical Forum 1 09-01-2008 07:01 PM
Too much info...help rxl TJ Wrangler Technical Forum 5 02-28-2008 02:05 PM
Factory Warranty info? Top info? BlueRidgeRunner TJ Wrangler Technical Forum 5 06-27-2004 04:52 PM
need some info about this... wakeboarder 21 TJ Wrangler Technical Forum 1 10-15-2003 06:01 PM
