SYE SS101-231 Help? - JeepForum.com
post #1 of 22 Old 01-07-2014, 11:02 PM Thread Starter
Kudu
SYE SS101-231 Help?
Only ID is SS101-231. Searched far and wide no one seems to know who makes this or if it is still made. I need seals, anyone. If I cannot track down parts what to do? buy a new sye and start over?
Kudu is offline
post #2 of 22 Old 01-07-2014, 11:19 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pics?
Luck Favours The Prepared
Anticanman is offline
post #3 of 22 Old 01-08-2014, 11:07 AM Thread Starter
Kudu
Looks like a quality product. Just haven't been able to find that stamp # on any brand.
Kudu is offline
post #4 of 22 Old 01-08-2014, 11:17 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Your best bet would be to get an inside and outside measurement and get a new seal based on that. Napa carries oil seals and competent employees can look up that info. Seems like a rugged ridge though. Some of the older ones had identical seal issues. Call them and see if its theirs
post #5 of 22 Old 01-09-2014, 10:05 AM Thread Starter
Kudu
Was not a RR I called them. They told me to try JBconversions and Advance. I will confirm with the companies also.
Is there even a seal/gasket where the housing bolts on to the TC or do you make one with RTV? I havn't seen a gasket for sell for that location even with stock parts.
Kudu is offline
post #6 of 22 Old 01-09-2014, 11:20 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's rtv, sir.
post #7 of 22 Old 01-21-2015, 04:37 PM
Usmc0217
Did you ever figure out what brand your SYE is ? I have the same issue
Usmc0217 is offline
post #8 of 22 Old 01-21-2015, 09:09 PM
JrTjK
1978 FSJ Wagoneer
Most standard SYE's are made by the same supplier...for the low price, I'd give this a try http://www.jeep4x4center.com/oil-sea...FewF7AodWWAA4w
JrTjK is offline
post #9 of 22 Old 01-21-2015, 10:15 PM
Usmc0217
I've already tried that one , All I have to go by is the The markings on the sye "ss101-231 " the seal has these numbers marked on the seals rubber,"182 275 187 31 T10 F4206 1" any ideas ? I've tried going to all the auto parts stores but no one is competent enough to get me the right seal.
Usmc0217 is offline
post #10 of 22 Old 01-21-2015, 10:34 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'll try my timken dealer tomorrow if you would like
post #11 of 22 Old 01-21-2015, 11:23 PM
ravenworks
Call ECG and ask them,all you really need to do is measure the seal or the ID/OD of the shaft and seal.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #12 of 22 Old 01-22-2015, 09:28 AM
Usmc0217
I'd appreciate that, maybe ill give it another go around with another auto parts store.
Usmc0217 is offline
post #13 of 22 Old 01-22-2015, 01:59 PM
Schaef81
That looks a lot like my PORC SYE Kit. I had to use a National Seal 3946 to replace it. The PORC SYE kits were know to leak out the output seal.
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #14 of 22 Old 01-22-2015, 05:46 PM
sptrmike
sptrmike's Avatar
I dont know where Woolwich is, but there is Allied Bearing in Portland and Bangor they carry an extensive line of oil seals.
sptrmike is offline
post #15 of 22 Old 01-22-2015, 05:53 PM
bowtech
I would pull the seal, get the measurements and find a National, or Timken replacement, or take the seal to the parts house and have them measure and cross it over for you.
bowtech is offline
