SYE with regular driveshaft? - JeepForum.com
post #1 of 12 Old 04-16-2010, 05:45 AM Thread Starter
CJ51973
CJ51973's Avatar
I mean without a double cardon joint. Any way this works? Does anyone sell one? With all the DS length gain by getting the slip yoke out of there it would seem a ujoint DS would work fine with moderate lift. And this is much cheaper to buy/modify/maintain. I had a CJ5 (T18A) with a 12" DS running at about 13 degrees at each joint and it was happy.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #2 of 12 Old 04-16-2010, 06:54 AM
Louie4
Maybe you can make it work with a CJ DS? You would have to see what the u-joint sizes are for the CJ cause I think they are larger.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 12 Old 04-16-2010, 07:48 AM
TSEJEEPERS
If you pinion angle is correct I do not see why you could not.
You are still going to have to have a driveshaft made. One with a slip yoke in it.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 12 Old 04-16-2010, 08:47 AM
Apollo12227
As TSEJeepers stated, you need a driveshaft with slip in it... the CV part isn't necessissarily required but you must have slip in the shaft it's self. The whole reason you have a "slip-yoke" is to allow inward and outward movement of the driveshaft when the suspension experiences a shock (speed bump, off road, etc.). If there is not slip in the driveshaft OR in the yoke, you have a solid pice of steel connecting the driveshaft yoke to the transfercase yoke... When you hit a bump, it forces the driveshaft into the transfercase or into the pinion yoke, eventually one will give. You will 100% break the rear half of your transfercase, or destroy your pinion bearing if the driveshaft does not have a way of moving whenever the suspension experiences shock. At the shop I get people comming in all the time where the splines on the driveshaft siezed and wasn't letting their driveshaft expand and compress and it's amazing what that will do to a rear end.
The "CV" part of the driveshaft just allows for better driveline angles, most people dont know it but the most important part of the "CV" driveshaft they are putting in after getting a fixed yoke (SYE) is the part in the middle that allows the driveshaft to compress. Again, the "CV" part is just to allow constant velocity of the ujoints on both ends of the driveshaft which prevents wobbling and/or vibration.
Apollo12227 is offline
post #5 of 12 Old 04-16-2010, 08:51 AM
headstrong50
i just bought a sye for my np231. i have a buddy who took a front drive shaft out of a cherokee and had it cut down and balanced, hadnt put it in yet though. that works doesnt it?
going off road is like being married, its great until you bang something you shouldnt.
headstrong50 is offline
post #6 of 12 Old 04-16-2010, 08:53 AM
Apollo12227
Yes, that works perfectly, it's actually a very popular mod. The reason it works is because the cherokee shaft has the section in the middle that allows you to stretch and compress the driveshaft... Put simply, it has the "really thin part in the middle".
Here is a picture of what i'm talking about... Click on the link and have a look, in the middle of the shaft, it narrows down, this allows the driveshaft to slide out longer and shorter.
http://www.quadratec.com/Assets/Imag.../105979-md.jpg
post #7 of 12 Old 04-16-2010, 09:09 AM
headstrong50
Yeah, that beats spending 400$ on a slip yoke drive shaft. although..when i was at the junkyard yesterday pulling some parts, while i was surrounded by cherokees, i thought it was the rear drive shaft...needless to say, i didnt find what i was looking for, and when i got home my buddy finally called back and informed me it was the front drives shaft. that was after i looked in about 20 cherokees for the drive shaft.
post #8 of 12 Old 04-16-2010, 11:08 AM Thread Starter
CJ51973
CJ51973's Avatar
Yep, I understand the shaft needs to slip. The Cherokee front is a good idea. I have a good shop for shortening/balancing. I was just wondering with a 16" or so shaft if it was necessary for it to be CV. I thought the yoke might be different between a CV and regular ujoint yoke. If so the SYE would need a differnt yoke.
CJ51973 is offline
post #9 of 12 Old 04-16-2010, 09:29 PM
fratis
fratis's Avatar
yes the yokes are different.
fratis is offline
post #10 of 12 Old 04-17-2010, 08:46 AM
1998zj
Hey Headstrong, which yard do you go to? I used a XJ front shaft for mine and it worked out great.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #11 of 12 Old 04-17-2010, 09:25 AM
stoveguy01
I done just what your asking about on a cherokee I used to own. I just went to the wrecking yard with my driveline measurements and and ujoint and started searcing tell I found one the length I needed with correct u joints than got the u bolts for a driveline and maounted it to the yoke that came with the sye kit drove it like that for 2 yrs tell I lifted it more and needed to go to a double cardan style. hope that helps
stoveguy01 is offline
post #12 of 12 Old 04-17-2010, 11:09 AM
headstrong50
i go to pick-a-part. and sometimes pull-a-part.
Regular Maintenance Osmosiz TJ Wrangler Technical Forum 9 01-09-2009 11:43 AM
nyloc nut vs regular nut Dantheshan YJ Wrangler Technical Forum 6 01-01-2009 06:40 PM
Regular TJ Soft Top on a LJ Ala05Unlimited TJ Wrangler Technical Forum 18 10-20-2006 12:51 PM
Argh, regular LJ? Deezul TJ Wrangler Technical Forum 13 12-22-2005 06:30 AM
what can the rubicon do that a regular tj cant? idcx3 TJ Wrangler Technical Forum 49 02-15-2003 09:28 AM
