SYE question - JeepForum.com
post #1 of 10 Old 10-17-2007, 08:40 PM Thread Starter
Stout95YJ
SYE question
Just installed 4" RE lift, buying an SYE soon, will just an SYE kit get rid of these noises and vibes? and Do I have to run a CV shaft with an SYE kit?
Stout95YJ is offline
post #2 of 10 Old 10-17-2007, 08:45 PM
enil01
enil01's Avatar
You need the CV shaft too.
'93 4.0L YJ Becky
RE 4.5" XD lift | 33" TRXus M/Ts | Warn M8000 | Herculined | OBA
_|_
--X-X-(_)-X-X--
<3 EP-3Es
enil01 is offline
post #3 of 10 Old 10-17-2007, 08:55 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
you don't need a cv shaft with a sye. i ran one for 3+ years with no problems what-so-ever. i think it was a CJ shaft that was tweaked for lenth if i remember right...
just be sure if you have a cv yoke you run a cv shaft or you will limit the ujoint's ability to run at a steeper angle.
-Erik <--- "accidentally" ran a u joint in the cv yoke for 3+ years with minimal problems, whoops
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #4 of 10 Old 10-17-2007, 08:57 PM
Jeffro06
Jeffro06's Avatar
And you'll have to replace those 4 degree shims....I've got 8 degree shims coming tomorrow! Then, hopefully, I'll lose the transfercase drop, and the last of that vibration! Just takes getting the pinion to point at the transfercase, or so I'm told.
I didn't have any vibes with the 4" lift, and the transfer case drop, but the driveshaft angle just scared me.
Jeffro06 is offline
post #5 of 10 Old 10-17-2007, 09:10 PM
crb577
yeah I use a cut down XJ shaft works perfect and is pretty cheap
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #6 of 10 Old 10-18-2007, 01:04 AM
enil01
enil01's Avatar
Dag why didn't I think of that simple solution. I stand corrected.
'93 4.0L YJ Becky
_|_
--X-X-(_)-X-X--
<3 EP-3Es
enil01 is offline
post #7 of 10 Old 10-18-2007, 06:02 AM
chupacabrah
chupacabrah's Avatar
same here.
AA SYE - $200 shipped
CV shaft (99 xj out of junkyard) - $50
local shop cut and balance CV shaft - $58
replace ujoints in d-shaft (3 x $15ea) $45
if you get sye and cv shaft, remember also that your rear pinion has to be pointing towards your tcase. tom woods' site has some pictures and stuff describing the driveshaft geometry
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #8 of 10 Old 10-18-2007, 07:53 PM Thread Starter
Stout95YJ
So I can get a CV shaft out of an XJ ? any specific years?
post #9 of 10 Old 10-18-2007, 08:43 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
a CV style shaft isn't 100% necessary but some type of new shaft is. the stock shaft a) isn't long enough and b) won't be able to expand and contract anymore with a fixed yoke output on the t-case. since you're going to need a new shaft anyway most people opt to run a CV style to be sure there aren't any vibes.
as for years for the XJ, pretty much any 90's model will work IIRC. mine came from a 97 with an auto.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #10 of 10 Old 10-19-2007, 06:16 AM
chupacabrah
newer the better, i think. 97-99 is pretty safe.
it's the front driveshaft, btw, if you didnt realize.
-Jon
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
