Quantcast SYE Intall question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > SYE Intall question
Old 05-03-2007, 08:30 PM   #1
theonecsf
SYE Intall question
Do you have to remove both the front output shaft to remove the rear output shaft? I am planning on installing the Kit with the Trans Case still attached to the Tranny. Can I get away without disconnecting the front drive shaft and output shaft?
Thanks in advance,
theonecsf is offline   Reply With Quote
Old 05-03-2007, 08:42 PM   #2
Devildog985
You need to remove it so you can slide it all out.
1994 YJ 5" bds Lift with M.O.R.E 5/8 boomerange shackles and BDS stretch, 1" Daystar Bl, SYE/W XJ d/shaft 8.8
YJ Nation - Big Jim Team YJ - The Revolution Begins
Devildog985 is offline   Reply With Quote
Old 05-03-2007, 09:03 PM   #3
ckiel24
Just drop the transfer case. If you search, everyone agree's that it is easiest to just drop the entire case.
ckiel24 is offline   Reply With Quote
Old 05-04-2007, 06:33 AM   #4
dell2028
Drop the case. Its pretty easy. Remove the shifter when you do it. Also, put something in to hold the tranny when you drop the x-fer case skid plate.
My Build Up
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline   Reply With Quote
Old 05-04-2007, 10:06 AM   #5
FSTG60MAN
Did mine in a few hours wihout removing the t-case. I think its a matter of preference.
sold the zj back in a yj, skyjacker 7000 absorbers, bfg 31x10.5x15 all terrains, hella lighting, highlift and more tow straps than god.
FSTG60MAN is offline   Reply With Quote
Old 05-08-2007, 07:46 PM   #6
theonecsf
Many thanks
Thank you all for the info, the install went well.
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
