Sye installation problem - JeepForum.com
post #1 of 15 Old 05-30-2013, 07:48 PM Thread Starter
GootsYJ1990
All has went well until this point. One of the shafts that comes out of the case is to long. am i supposed to cut it down because on all the instructions pictures they all look way shorter than mine. And the cover wont slide on right because that piece sticks out to far. I have taken it apart a few times and everything seems to set into place right. Please see pictures. Kit is a rugged ridge
The shaft on the left is to long.
image-1591383053.jpg   image-4002921250.jpg   image-1231638542.jpg   image-1320392412.jpg
"The only easy day is yesterday."
GootsYJ1990 is offline
post #2 of 15 Old 05-30-2013, 08:39 PM
merlin87yj
1987 YJ Wrangler
I had the same issue when I installed my SYE. The instructions that came with my kit said on some T-cases the shaft might have to be cut. I seem to recall that the shaft could not extend
more than 3/4 of an inch from the case, check with your SYE manufacture to be sure of the length. I used a 3" cut off tool and then a file to smooth off the edges. Works great.
merlin87yj is offline
post #3 of 15 Old 05-30-2013, 11:14 PM Thread Starter
GootsYJ1990
I cut slightly less that 3/4 of an inch and it seemed to work. I should have it installed tmrw morning. Thanks for your input!
post #4 of 15 Old 05-31-2013, 12:22 AM
Reno72
yes, use a cut off wheel and cut it to less than 1", that should do it.
Reno72 is offline
post #5 of 15 Old 05-31-2013, 08:26 AM
Lemoore-on
I just did this to mine yesterday. Mine is a JB & the directions said to mesure the shifter rod, if it is 10.2" cut it down to 9.38" (typicaly 88 to 89 models) I ASSUMED my 92 would be ok, put it all back together and it wouldn't shift. Took it back apart and the rod mesured 10.2"! cut it, put all back together and now it shifts fine!
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #6 of 15 Old 05-31-2013, 08:54 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I've had to cut a few down so far mostly on the older cases.
Luck Favours The Prepared
Anticanman is offline
post #7 of 15 Old 05-31-2013, 10:41 AM Thread Starter
GootsYJ1990
Yeah I'm about to start putting it back in the heep. No more tcase drop . After I'm done with that I'm taking it to my buddies to swap in the 8.8
post #8 of 15 Old 05-31-2013, 10:58 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Good for you!!!
post #9 of 15 Old 05-31-2013, 11:01 AM Thread Starter
GootsYJ1990
Good for you!!!
Thanks :'D it's like an early Christmas today is
post #10 of 15 Old 05-31-2013, 11:15 AM
DirtKar
Maximum Effort
DirtKar's Avatar
Ok, ok, I'll pile on. I cut mine too.
YJOTM JULY 2014
DirtKar is offline
post #11 of 15 Old 05-31-2013, 11:27 AM Thread Starter
GootsYJ1990
You guys are sneaky I didn't see this in any of the sye threads. Thank you all for your input
post #12 of 15 Old 05-31-2013, 12:02 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It showed up in almost every set of directions that I've read to install sye's. Which was the first two.
post #13 of 15 Old 05-31-2013, 01:52 PM
dailydrivenyj
I know you already had other posters address your questions, but heres a great video that address that pin very quickly so if you dont pay attention you will miss it.
dailydrivenyj is offline
post #14 of 15 Old 05-31-2013, 02:17 PM
jbolty
jbolty's Avatar
Make sure you cut the right end. Just sayin'
jbolty is offline
post #15 of 15 Old 05-31-2013, 06:45 PM
Lemoore-on
I'm doing the same thing
Mike
