sye on d35 to 8.8 - JeepForum.com
post #1 of 13 Old 03-05-2014, 05:56 PM Thread Starter
RCwheelin
sye on d35 to 8.8
Hi guys, I want to get rid of my t case drop and go for an sye. I currently have a d35 but want to upgrade to a 8.8 in the future. I will have the sye installed with the d35 before I do the swap. My question is will I have to modify or buy a different/longer driveshaft when I do intend to do the 8.8 swap or can I just reconnect the driveshaft to the 8.8 without any problems?
93' YJ
RCwheelin is offline
post #2 of 13 Old 03-05-2014, 05:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll probably have to shorten the driveshaft from the Dana 35 to the 8.8. Why not just swap it all at the same time? That's one set of perches and one driveshaft.
Patience
Luck Favours The Prepared
Anticanman is offline
post #3 of 13 Old 03-05-2014, 06:03 PM Thread Starter
RCwheelin
Patience
If it needs to be shortened than I will wait to do it at the same time, no sense in spending that extra time and money. Thanks for the quick reply
93' YJ
post #4 of 13 Old 03-06-2014, 08:33 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I intalled an AA SYE and Tom Wood's shaft with my 35. Everything was fine when I put the 8.8 in.
Randonexplosion is offline
post #5 of 13 Old 03-06-2014, 02:50 PM
Dwarf
1987 YJ Wrangler
I did the same upgrade, but I did mine all at the same time. I also took the opportunity to change the pinion angle.
Dwarf is offline
post #6 of 13 Old 03-06-2014, 02:52 PM
Lemoore-on
I did my SYE & 8.8 at the same time also.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #7 of 13 Old 03-06-2014, 03:25 PM
0III0forlife
1987 YJ Wrangler
The pinion on the 8.8 sits further forward than the 35, but it also sits further toward the passenger side. So they more or less cancel each other out.
I did the SYE on mine when I still had the 35, and when I did the 8.8 the slip yoke on the CV shaft never changed on how far it was on the splines.
0III0forlife is offline
post #8 of 13 Old 03-06-2014, 08:35 PM
blitz134
Agree with this...d35 first with sye and cv shaft...then put in 8.8 with the same shaft.
The 8.8 pinion is only 1/8" longer...and as mentioned before is offset more than the d35 which makes up for it
Current Jeeps (Click to see build threads):
blitz134 is offline
post #9 of 13 Old 03-06-2014, 08:49 PM Thread Starter
RCwheelin
Ok thank you this makes my plan flow a little easier.
93' YJ
post #10 of 13 Old 03-07-2014, 01:49 AM
kgb_m3
For those of you that ran CV style shaft with d35, how was the pinion angle setup? I would imagine shims as I really doubt anyone took time to weld perches at correct angle on the d35. Might as well put the time into the 8.8
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #11 of 13 Old 03-07-2014, 06:59 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I installed an AA SYE and Tom Wood's shaft with my 35. Everything was fine when I put the 8.8 in.
Same here. I told Tom what my plans where, when I bought them. He told me that it probably wouldn't be a problem. And if it was, he'd adjust it for free.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #12 of 13 Old 03-07-2014, 01:29 PM
Reno72
I think I used 8 degree shims to get the right angle, of course once you go 8.8 you'll be setting the perches so the shims are temporary.
Reno72 is offline
post #13 of 13 Old 03-07-2014, 09:00 PM
kgb_m3
That information helps a lot. I can split the project into 2 parts and have minimal down time. Then give the shims to the next guy.
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
