Switch Panel With Carling Contura II - Page 3 - JeepForum.com
post #31 of 31 Old 11-09-2012, 09:12 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by idgara007 View Post
true true, but along with that I need to choose wiring to hook up these switches as well. Im not sure if the switches say how much power is required for the LEDs in them. They say a max of 20amps but I know it takes much less just to power the LED. technically if I ran 5 in parallel they would all see the 12volts but the current would increase 5 fold, so I would need larger wire to accommodate this correct?
I dont really want to run 10ga wire just for switches because it is very thick and stiff. If I only ran 18 ga there is a risk of possibly overloading the max current for that wire.
FYI: i would be running switches for relays to lights and compressor system and the only direct power would be to the CB which only needs 2amps anyways. so nothing of a major power draw.
another point of curiosity looking at the OPs pics, how were you able to crimp in both wires to one terminal? it looks very clean but I cant seem to figure how to do them like that. speaking of which, what terminal (and source if any) did you use in the connector housing you linked?
When I ran my switches, I only used 12 gauge from the battery to power them (now its the remote wire from the stereo 20 gauge wire I think) and I used cat5 to run it to the relays. It only takes milliamps to activate a relay so put the good wire where it counts.
Luck Favours The Prepared
Anticanman is offline
Switch panel Speed94 TJ Wrangler Technical Forum 6 10-12-2010 09:00 AM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 10:21 PM
switch panel ARCHERYNGUNS JK Wrangler Technical Forum 30 04-15-2009 03:55 PM
Wiring Aux Lights with Contura Switch Raztt TJ Wrangler Technical Forum 8 08-30-2008 06:52 AM
switch panel hillbillybob TJ Wrangler Technical Forum 2 03-15-2007 03:09 PM
