Swaybar Removal Issue - JeepForum.com
post #1 of 20 Old 04-30-2013, 10:10 PM Thread Starter
Fhajad
I'm attempting to remove the rear sway bar on my YJ, but can't get it off. I put a T55 torx bit on the head but it seems to slide out like it's too small. But any other size bigger (T60) is too large.
How am I supposed to remove the sway bar if I'm unable to undo it on the torx head side?
Fhajad is offline
post #2 of 20 Old 04-30-2013, 10:13 PM
zte87
GIVE IT THE ONION
zte87's Avatar
You mean track bar not sway bar but any way, you could always take the die grinder/sawsall to it. You will never want to reinstall it any ways!
zte87 is offline
post #3 of 20 Old 04-30-2013, 10:25 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Make sure it's clean in there or the T55 wont fully seat. If it's clean, grind it off, it's stripped. You will never use them again.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #4 of 20 Old 04-30-2013, 10:46 PM Thread Starter
Fhajad
It's clean, but when you try to wrench it's like it's too small. So it's probably stripped.
I'll have to either bust the nut off or pay someone to grind it. Thanks!
Fhajad is offline
post #5 of 20 Old 04-30-2013, 10:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I use the t55 to hold the bolt and I think a 18mm on an impact to remove the nut. Moving the bolt isn't gonna do anything but cause trouble. Torx style of trouble.
Anticanman is offline
post #6 of 20 Old 05-01-2013, 04:50 AM
bestos
yeah, i used the t55 to hold it - and used impact to get the nut.
1995 YJ - 33" BFG KM2 - 4.88 w/ Aussie front locker. 2.5" OME. 5/8" shackle. 1" JKS body.
1991 YJ - 4.0 - Stock and banged up and recent purchase
bestos is offline
post #7 of 20 Old 05-01-2013, 05:52 AM
EABiker
I left the ends attached, and used a sawzall to cut the bar out.
EABiker is offline
post #8 of 20 Old 05-01-2013, 06:40 AM
bogleparsons
don't pay someone to grind it off....
Just buy a grinder and a cutting disk and do it yourself.
Won't be the last time you use the grinder.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #9 of 20 Old 05-01-2013, 07:09 AM
jaycal3
So I finally bit the bullet after almost knocking the fillings out of my teeth over bumps and took a sawzall to my Track bars this weekend... I wanted to get them off the right way in case I had to put them back on but the stupid Torx is a PITA! I can honestly say, I am pissed at myself for the last year of kidney busting rides... Its still a jeep and not smooth by any means but I will say there is a night and day drastic difference between running with and without track bars. I am glad I did it and even after almost an hour on the highway at 65-70 MPH I am glad... The Jeep does not wander and is not squirrely at all. Sawzall those puppies off!!!
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #10 of 20 Old 05-01-2013, 08:13 AM
pasinbuy
No, really? You mean that 99% of the posters here are right?
Well can you imagine that!
Removing both track bars is the cheapest and best upgrade you can do to your Yj.
pasinbuy is offline
post #11 of 20 Old 05-01-2013, 08:35 AM
dancytron
You should really try to take them off without ruining them.
If your state has a safety inspection and you get someone who knows what they are looking at, you might need to put them back on to pass (and then take them back off).
I had trouble getting one of the torx bolts off. I ended up cutting the nut off with a dremel tool. It took forever, but I was afraid I'd mess something else up it I used my angle grinder.
dancytron is offline
post #12 of 20 Old 05-01-2013, 08:52 AM
lincolnmatthews
2015 JK Wrangler
Hope this isn't hyjacking this thrd but a dumb %^# quest why did they put them on in the 1st place if all you guy say take them off? I'm been a little hesitant I thought it might wander more on the hwy or the rear end may move more. I'm wondering if some of the vibes I get when I take off maybe coming thru the rear track bar as the rubber is gone & its rubbing against the frame brkt.
lincolnmatthews is offline
post #13 of 20 Old 05-01-2013, 09:11 AM
zte87
GIVE IT THE ONION
zte87's Avatar
Look at the ch7 you won't find a single track bar on that thing, jeep install them to help make them "safer"....... They had a bad wrap for rolling etc. but when they made the move to the yj they did several thing to make is safer a couple things for example are the wider leaf springs, wider axle etc.
zte87 is offline
post #14 of 20 Old 05-01-2013, 09:38 AM
Kuntryboy816
Kuntryboy816's Avatar
To the OP... if you don't want to buy a grinder you can put vice grips on the nut side and drill out the bolt from the head side. Use a bit a size or two smaller/thinner than the bolt's shaft and drill straight to where the nut sits. Then BFH that SOB off. 8) I'd still look at getting a grinder though. Like Bogleparsons said, it won't be the last time you use it... especially owning a Jeep. My Dewalt grinder has to be one of the best tools I've purchased and it gets used regularly.
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #15 of 20 Old 05-01-2013, 10:11 AM
Charles88yj
Is it still good to remove the track bars having a SOA lift?
Weber carb, Nutter Bypass.
Mud-Terrain tires 33x12.50
SOA Lift and Rancho RS5000 Shocks
And thinking of lots more!
Charles88yj is offline
