Sway and Track Bars.....any use for them?? - JeepForum.com
post #1 of 4 Old 10-10-2001, 03:49 PM Thread Starter
powjunkie
I used to disconnect my sway bars everytime I went out on the rocks. And of course, there were a few times that I didn't feel like reconnecting till I got home. After a few times, I realized that I couldn't tell a difference on the road either way so I took them off for good. As far as the track bars (frame to axle bars), I was feeling brave one day and removed them for increased articulation. Same thing, couldn't tell a difference on the street. Anyone know of long term bad stuff that can come from this?
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #2 of 4 Old 10-10-2001, 04:41 PM
Nightclaw
I've been running !Sway and !Track for almost a year now with no significant drivability issues. I notice a LOT of body lean, but then again I tend to forget I'm driving a Jeep once in a while...
Nightclaw is offline
post #3 of 4 Old 10-11-2001, 09:05 AM
Tman
When I bought my YJ it had a 2.5" lift 31" ATs and both track bars and sway bar attached. It cornered like a race car. It also off-roaded like one. After dumping my trackbars and making a sway disconnect I definitely feel the rig being much looser all around. It's of course leaps and bounds better off-road. I'm now SOA and it's even worse. You just have to drive it with it in mind. It's very hard to make a trail rig ride like a car. I'm fine in a straight line cuz everything is aligned properly but emergency lane changes are scary! At any rate you have to be mindful and drive accordingly. Remember, if you hit somebody with a modified rig or even if they hit you (!) they can get after you and sue you out of your hide blaming lack of maintenance, improper install, etc. Better not to give them an excuse.
'91 YJ SOA 8.8 locked OBA OBW <a href="http://mywebpages.comcast.net/t.molnar" target="_blank">mywebpages.comcast.net/t.molnar</a>
Tman is offline
post #4 of 4 Old 10-11-2001, 11:52 AM Thread Starter
powjunkie
Thanks for the info guys. I've been running like this for over a year now, but was wondering if anything was getting thrown out of wack cuz of it. Like you say, once you adjust your driving habits, it's a no brainer.
sway bars, track bars....WTF!!! skipilot YJ Wrangler Technical Forum 4 03-01-2009 09:57 PM
track & sway bars do i need them? rficken42 YJ Wrangler Technical Forum 16 12-17-2008 11:53 AM
Shackles, Track Bars and Sway Bars dabomb5756 YJ Wrangler Technical Forum 23 05-02-2005 10:22 PM
Sway and Track Bars prossett YJ Wrangler Technical Forum 14 11-22-2004 09:56 AM
Disco's Sway Bars and Track bars biffstephens TJ Wrangler Technical Forum 1 10-23-2004 04:34 AM
