sway bar disconnects - JeepForum.com
post #1 of 4 Old 05-17-2001, 09:08 AM Thread Starter
winokko
Hopefully not too dumb a question.....whats the frickin trick to get the top bolt loose on the stock sway bar. I tried a bit of hammering & a prybar but to no avail! Seems I'm going to have the same problem when getting the center bolt out for the new steering stabilizer/shock. Thanks In-advance
95, 4.0, 4" sky jacker lift, warn 9500i, tomken rear w/ swing out, 33x12.5 pro comp mud's, 3" body lift, sway disconnects, NO track bars & custom front bumper
winokko is offline
post #2 of 4 Old 05-17-2001, 12:03 PM
wilhelm
winokko
i had the same problem with the swaybar links.i had to remove the whole assembly(swaybar&links)to be able to hit it harder with a hammer.(the bolt might be fused to the bushing sleeve)
as for the stabilizer; try a balljoint/tierod fork,if not,i had to remove the tierod from the steering knuckles and the center link and the stabilizer came right off . wilhelm nj
wilhelm is offline
post #3 of 4 Old 05-17-2001, 12:59 PM
Kamicosmos
Dunno about the sway bar, will find out later this summer.
As far as the steering stabilizer goes, I just did mine...wow...I beat on that siezed up thing for a while, till I realized I squished out the bolt a bit so that once it broke free it wouldn't come out of the hole. So i hacksawed off the mushroomed end of the bolt, and then used a tierod fork to lever the thing out. The Rancho that replaced it uses a much more logical setup for the bolt, so hopefully I won't have to go through that again!
So anyways, my point is, don't beat on it, go get on of those forks first! Mine was 10.99 at Advance Auto...looks like a big tuning fork.
Dave
95 YJ
Dave
95 Rio Grand YJ
Kansas City, Missouri
http://kamicosmos.jeepz.com
Kamicosmos is offline
post #4 of 4 Old 05-17-2001, 01:38 PM
damonejeep
I had the same issue abou the top bolt of the sway bars. You need to get a ball joint seperator, or pickle fork. Place it inbetween the swat bar and the connections, and hit it hard young man. If will take any where from 30 - 100 hits for it to come off.
If you look in hte suspension section, look for the topic named swaybar discos. I got some good advice.
Good luck and have fun.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
Tell me about sway bar disconnects JVona TJ Wrangler Technical Forum 2 03-29-2009 12:29 PM
Sway Bar Disconnects pjleslie03 TJ Wrangler Technical Forum 7 10-24-2008 11:51 AM
Sway bar disconnects Cobra001 TJ Wrangler Technical Forum 11 07-20-2008 10:25 AM
Which Sway Bar Disconnects for my X? Meir10 JK Wrangler Technical Forum 7 12-16-2007 03:11 PM
sway bar disconnects tracker TJ Wrangler Technical Forum 2 03-23-2007 11:58 AM
