Sway Bar Disconects - JeepForum.com
post #1 of 3 Old 07-10-2001, 12:37 AM Thread Starter
shea324@aol.com
Sway Bar Disconects
I am relatively new to offroading, and have never driven with my sway bar disconected. But I was thinking, why disconnect both sway bar links? (Assuming you are planning on putting it back together) If one is free, doesnt that accomplish the same thing?
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #2 of 3 Old 07-10-2001, 11:47 AM
damonejeep
I understand what your are thinking. But no. To gain added wheel travel, you need to have both disconnected. WIth only one disconnectde you will obtain more travel with one of the wheels. Do yourselt a favor and buy some disconnects,you will be glad you did.
Sway bar discos will run you around $75-90. They are not to difficult to put in and easier to disconnect. I have been running JKS and love their solid construction.
My recomendation is to buy a par and disconnect both ends when off-roading. You'll be happier.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #3 of 3 Old 07-10-2001, 08:25 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
If you have the right tools (grinders, drill press) you can make your own disconnects for pennies.
I drew up a graphic on how the general ones are made up .. there is a little stress on the parts, so make sure that you use strong steel.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Rubicon Express Sway bar Disconects ? mhaskin TJ Wrangler Technical Forum 13 10-14-2009 07:53 AM
Installed my JKS disconects but..... Qckslvr TJ Wrangler Technical Forum 2 05-05-2006 12:21 PM
JKS disconects cliffmelanie1 TJ Wrangler Technical Forum 11 12-29-2005 02:21 PM
sway bar disconects how to>??? biggreentj TJ Wrangler Technical Forum 24 09-13-2004 09:00 AM
sway bar disconects f1ipst3r YJ Wrangler Technical Forum 2 03-30-2004 04:54 PM
