Sway bar - JeepForum.com
post #1 of 10 Old 10-25-2001, 08:20 PM Thread Starter
Sarge37
Sway bar
hello everyone, I was curious about the Sway bar and quick disconnects. Does it help to remove the Sway bar? If so, what does it benefit? Have seen mention of quick discoonects and people taking them off for off road use. Any help would be appreciated.
"If It Aint Broke, Fix It Till It Is!!!!!"
05 TJ Rubicon, 4.0L, 6 Speed.
07 Ram 1500 Quad Cab
Sarge37 is offline
post #2 of 10 Old 10-25-2001, 08:31 PM
bob91yj
Your sway bar ties the frame of the Jeep to the front axle. This prevents excessive body roll for street driving, but limits your axle articulation when off roading. Quick disconnects allow you to disconnect your sway bar without having to unbolt anything, usually you just have to remove a pin and pull the sway bar up out of the way. It's not a bad idea to bungie cord the sway bar up when it's disco'd.
There are people that run on the street without a sway bar, but it can be a little unnerving at times, and I wouldn't really recommend it.
Removing the factory sway bar links can be a real chore, and may require a pickle fork for the upper stud, it's a tapered stud.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 10 Old 10-26-2001, 12:46 AM Thread Starter
Sarge37
Thanks Bob, That was alot of help. I think I'll leave it alone for now.
Sarge37 is offline
post #4 of 10 Old 10-26-2001, 01:32 PM
SBgreenYJ
Im actually working on a project for my advertising class here at school concerning a remotely disconnecting sway bar. What I have found already is that because YJ's have leafs, you can get away with disconnecting your sways and leave them off for on road driving. When you get to springs on the TJ's for example, you have more independent front and rear suspension (Hence why TJ's generally "flex" easier than YJ's)
'95 YJ 4.0L
SBgreenYJ is offline
post #5 of 10 Old 10-26-2001, 01:39 PM
I-4
I-4's Avatar
completly removed the sway bar from my yj!made a big difference offroad.on the street it changed the cornering but,it is very easily made up for in driving habits.it has a slight amount more of body roll.left the trac-bars in place.they don't effect off road performance that bad.it even rides better on the street.my wife even noticed the improved ride.just hope a state inspector doesn't have a bad day next inspection!anyone know if it is mandatory to have?
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #6 of 10 Old 10-26-2001, 09:24 PM
powjunkie
I've been running with my sway bars and track bars removed for a couple of years now. I notice a little more roll in the corners, but I wouldn't say it's changed my driving style.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #7 of 10 Old 10-27-2001, 02:54 AM Thread Starter
Sarge37
Thanks for all the info folks. Bottom line is would you let your 17 Year old daughter drive your YJ on the street w/o the Swaybars installed?
Sarge37 is offline
post #8 of 10 Old 10-27-2001, 06:48 AM
glm 87 wrangler
NO WAY I had a dog jump out in front of me when I had mine off.Was kind of hard to recover but some how i did.If another car was comming i would have been a goner.If she 17 i would giver her all the added help the jeep has to offer and then some.NOT SAYING SHE A BAD DRIVER!!But she 17...
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #9 of 10 Old 10-27-2001, 09:03 AM
powjunkie
In the words of the famous philosopher, Homer....Doh!!!
Definately want to leave everything attached.
post #10 of 10 Old 10-27-2001, 03:43 PM
jeffy
jeffy's Avatar
Really this would depend on what you've done to the Jeep? A suspension lift or Add-a-leaf would stiffen the suspension some. This would help keep the Jeep on track while onroad. It's not for everyone though. You have to think about the Trackbars offroad too though. Don't forget about those. I've cracked a extension bracket for the front trackbar when I left it on. I've heard of people cracking the cast sleeve on the housing before too.
Currently I drive with no trackbars and disco's on the swaybar. They were cheap $50 RE disconnects. I've driven years without the swaybar too. Takes some adjustments but not much. It's safe to say that a hardtop Jeep will sway a lot more then a soft top Jeep. The weigth really makes a difference.
Well anyway, where in hawaii are you. I'm on Oahu. email me if you like.
*** www.4BangerJP.com ***
jeffy is offline
Electronic-disconnecting front sway bar or Active Sway Bar System vgullotta JK Wrangler Technical Forum 16 08-30-2010 06:39 AM
Stock sway bar diameters.. can I run a smaller front sway bar? jondotcom TJ Wrangler Technical Forum 5 09-23-2009 02:24 PM
Sway Bar and Sway Bar Links -- MOOG? mmitsch TJ Wrangler Technical Forum 9 08-09-2009 11:21 PM
Sway or anti-sway? 1BadTJ TJ Wrangler Technical Forum 6 04-24-2004 08:49 PM
Sway Bar?? Corycool YJ Wrangler Technical Forum 2 06-24-2003 02:33 PM
