Swapping my Pro-Comp springs for RE's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Swapping my Pro-Comp springs for RE's
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 09-19-2006, 08:42 AM   #1
Austin_YJ
1987 YJ Wrangler
I'm taking off the 4" pro-comp springs that came on my jeep, and swapping to the RE extreme duty. Will anything else need to be changed? (I don't know the quality of the rest of the pro-comp components)
Austin_YJ is offline   Reply With Quote Quick reply to this message
Unread 09-20-2006, 08:20 PM   #2
Austin_YJ
1987 YJ Wrangler
No one has any input?
Unread 09-20-2006, 08:29 PM   #3
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I did the same thing. Assuming the springs are the same height you do not need to change anything else.
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote Quick reply to this message
Unread 09-20-2006, 09:49 PM   #4
Austin_YJ
1987 YJ Wrangler
I know the RE springs are supposed to be 4.5", but most end up more like 5.5".
Unread 09-20-2006, 10:17 PM   #5
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i doubt that you would notice any difference in an inch, unless you are already maxed out on the rear driveshaft lengh etc.
i went from 4 to 5.5inches and didnt notice anything at all.....just check all brake lines etc after you are finished.
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 09-20-2006, 10:17 PM   #6
paultyler
paultyler's Avatar
Mine weren't. If your springs are taller then you may need new shocks.
My Jeep - Video
My Jeep in the Snow
Unread 09-21-2006, 10:10 AM   #7
Austin_YJ
1987 YJ Wrangler
Thanks for the help guys. That is exactly what I wanted to know.
