Swapping my Pro-Comp springs for RE's - JeepForum.com
post #1 of 7 Old 09-19-2006, 07:42 AM Thread Starter
Austin_YJ
1987 YJ Wrangler
I'm taking off the 4" pro-comp springs that came on my jeep, and swapping to the RE extreme duty. Will anything else need to be changed? (I don't know the quality of the rest of the pro-comp components)
Austin_YJ is offline
post #2 of 7 Old 09-20-2006, 07:20 PM Thread Starter
Austin_YJ
1987 YJ Wrangler
No one has any input?
post #3 of 7 Old 09-20-2006, 07:29 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I did the same thing. Assuming the springs are the same height you do not need to change anything else.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #4 of 7 Old 09-20-2006, 08:49 PM Thread Starter
Austin_YJ
1987 YJ Wrangler
I know the RE springs are supposed to be 4.5", but most end up more like 5.5".
post #5 of 7 Old 09-20-2006, 09:17 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i doubt that you would notice any difference in an inch, unless you are already maxed out on the rear driveshaft lengh etc.
i went from 4 to 5.5inches and didnt notice anything at all.....just check all brake lines etc after you are finished.
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 7 Old 09-20-2006, 09:17 PM
paultyler
paultyler's Avatar
Mine weren't. If your springs are taller then you may need new shocks.
, Teraflex Bellyup,
post #7 of 7 Old 09-21-2006, 09:10 AM Thread Starter
Austin_YJ
1987 YJ Wrangler
Thanks for the help guys. That is exactly what I wanted to know.
Writeup for swapping springs computerguy JK Wrangler Technical Forum 19 02-12-2010 01:23 PM
Swapping out springs? IH8ROADZ TJ Wrangler Technical Forum 12 10-30-2008 09:59 PM
swapping to 3.5 inch springs? deryk111 TJ Wrangler Technical Forum 16 10-12-2008 10:14 PM
springs, axles, and swapping? jmathis3 YJ Wrangler Technical Forum 8 02-14-2008 10:35 AM
RE's tri-link on RE's 4.5 SF kit? Jeepin'J TJ Wrangler Technical Forum 6 05-29-2006 03:00 AM
