Swapping metal dash - JeepForum.com
post #1 of 12 Old 05-21-2008, 09:40 AM Thread Starter
Mark455SD
1961 CJ5
Swapping metal dash
I had an accident with my jeep a few months ago and my knee bent the metal dash. I see these real cheap on ebay and craigslist. Is it a fairly easy swap or am I asking for a headache.
Mark455SD is offline
post #2 of 12 Old 05-21-2008, 10:59 AM Thread Starter
Mark455SD
1961 CJ5
How do I take my doors off gets 30 replies.
post #3 of 12 Old 05-21-2008, 11:27 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
It is actually a fairly simple but time consuming process. How bent is it?? Can you just bend it back??? Pics????
The part that is going to suck the most is you have to take your column apart to get the dash over it. here is a good link on how to do that: http://www.epiccomputer.com/dale/jee...tilt/tilt.html
If you look up my speaker replacement thread, youwill see how the dash comes off.
Over a 24hr time frame. Give it a few min.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 12 Old 05-21-2008, 11:54 AM
cinneman
1930 MK Compass
You wouldn't understand.....
cinneman is offline
post #5 of 12 Old 05-21-2008, 12:08 PM
BlackRhino
BlackRhino's Avatar
There aren't a whole lot of people on at 8:00 in the morning
The dash isn't too hard to remove though, just a ton of screws and the part about disassembling the steering column.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #6 of 12 Old 05-21-2008, 12:49 PM
AuroraJeep
Its ok, like everyone else has said, its time consuming and a little boring. I just swapped mine out last week. For the the steering column problem I just cut the piece with a cut off wheel, one cut and flexed. I am planning on riveting it back into place, its really hard to notice.
AuroraJeep is offline
post #7 of 12 Old 05-21-2008, 05:10 PM
93jeepyj
what part of the dash panel hits the steering column ? It looks like if you just pulled the steering wheel ans the turn signal lever and tilt lever the dash would slide right over. I'm probably wrong but I just wondered as I might be swapping in a cj dash soon to replace my rotten and cracked stock dash
93jeepyj is offline
post #8 of 12 Old 05-21-2008, 06:25 PM
rustywrangler
You have it right. What I ment was the wheel and levers. But pulling the wheel if you have not done so before can be fun.
post #9 of 12 Old 05-21-2008, 08:03 PM
93jeepyj
oh ok cool I wasnt looking forward to tearing apart the column on top of the wiring mess swapping in the cj dash will already be
93jeepyj is offline
post #10 of 12 Old 05-21-2008, 08:23 PM Thread Starter
Mark455SD
1961 CJ5
Thanks guys. Big parts like steering columns im ok with. Its the wiring harness that im concerned with. and the heater controls. Will I be able to just unbolt everything off of the metal panel still connected or will I have have to disconnect everything and and reconnect. Ill take some pictures tomorrow rusty. I probably could bend it back but I would like to swap it because none of bolt holes line up anymore for the plastic panels.
post #11 of 12 Old 05-21-2008, 09:06 PM
rustywrangler
Ugh, sounds like it was painful. Your gonna have to unbolt everything and disconnect in the back. It is not that complicated. The center gauge pod is one connection and the heater controls come apart easily.
A word of advice though, before you start pulling apart, disconnect the batt. You can EASILLY ground one of the gauges or a switch contact and blow fuses. It really sux.
post #12 of 12 Old 05-21-2008, 09:07 PM
joe's_yj
joe's_yj's Avatar
dont go through all that horn crap, just remove the sterring column all together, theres a bolt in the egine bay that looses it, and 2 or three by the dash and the whole thing comes out.
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
Removing metal dash support write up Bl4cK_kNiF3 YJ Wrangler Technical Forum 14 04-13-2014 08:37 AM
light screech squeal at start up, metal on metal sound not moving rutacon05 TJ Wrangler Technical Forum 3 12-07-2009 02:06 AM
metal dash backing CostaRicaJeep YJ Wrangler Technical Forum 8 08-25-2009 04:27 PM
metal dash backing CostaRicaJeep TJ Wrangler Technical Forum 0 08-24-2009 08:53 PM
Is the metal 'dash' part available anywhere? citRon YJ Wrangler Technical Forum 9 08-09-2008 09:18 AM
