Swapping ba10 to ax15. speedo gear? - Page 4 - JeepForum.com
post #46 of 91 Old 01-03-2014, 08:59 PM
Mark05059
going to need a different speedometer cable as well no matter which adapter he goes with
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #47 of 91 Old 01-03-2014, 09:00 PM Thread Starter
huskerconan
1987 YJ Wrangler
Wow u guys r the best. Unbelievable. Thanks for the help
huskerconan is offline
post #48 of 91 Old 01-03-2014, 09:06 PM
jeepguy85
1987 YJ Wrangler
I disagree. If he stays mechanical and finds the part I am talking about, the existing cable on his 87 will hook right up. That is exactly what I did when I swapped in the NP231 on my 87 a couple of months ago. The mechanical speedo cable is 100% compatible. The only other thing the OP needs is the correct speedo gear for his tire size.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #49 of 91 Old 01-03-2014, 09:08 PM
jeepguy85
1987 YJ Wrangler
No problem. Hope it works out for you and Advance Adapters will sell you the speedo gear housing you need.
post #50 of 91 Old 01-03-2014, 09:17 PM
jeepguy85
1987 YJ Wrangler
OP, it is your lucky day! I found what you need in the link below on ebay! Better buy it while it is still available! It is the same guy I bought mine from.
http://www.ebay.com/itm/Jeep-Dodge-S...0554ec&vxp=mtr
post #51 of 91 Old 01-04-2014, 04:18 AM Thread Starter
huskerconan
1987 YJ Wrangler
Sold. thanks. Now if your still in the mood what pilot bushing did you install when you did your swap. I keep reading a bushing from a 73 cj5 will work, but may be a hair long. What do you think?
post #52 of 91 Old 01-04-2014, 04:19 AM
Mark05059
what shaft id is on your new transmission?
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #53 of 91 Old 01-04-2014, 06:35 AM Thread Starter
huskerconan
1987 YJ Wrangler
.75 thanks
post #54 of 91 Old 01-04-2014, 07:01 AM
Mark05059
so I do agree its probably the 360 pilot bearing..for like a cj5 or cj7 in the late 70 or early 80's
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #55 of 91 Old 01-04-2014, 07:13 AM Thread Starter
huskerconan
1987 YJ Wrangler
I can get one from AA so I will probably order it this weekend. I have read the ones from the can fit a little loose in the crank. Not sure if that's true just not willing to take the chance. I guess i will need to order the appropriate gear for the speedo also. Running 255.75.17s.Thanks and I will keep u guys updated.
post #56 of 91 Old 01-04-2014, 07:14 AM Thread Starter
huskerconan
1987 YJ Wrangler
Cj not can. Dam auto correct
post #57 of 91 Old 01-04-2014, 11:51 AM Thread Starter
huskerconan
1987 YJ Wrangler
I ordered the pilot bushing from Novak. I'm staying with the internal slave. Gonna replace with a new one. Any suggestions? Thanks
post #58 of 91 Old 01-04-2014, 01:04 PM
jeepguy85
1987 YJ Wrangler
I actually swapped in a NP231 TC to replace the NP207. I kept my BA10/5. It has 200k on it and is still running, so I elected to keep it. I will swap in an ax15 when it finally dies. It gets a bad rap, but like I said I have 200k on mine so it can't be that bad.
post #59 of 91 Old 01-04-2014, 06:00 PM Thread Starter
huskerconan
1987 YJ Wrangler
The tranny was pretty worn out so thought what the hell, got it cheap. This is going to be the kids jeep when he turns 16 here in about six months, getting ready to do the body and lift. should be fun.
post #60 of 91 Old 01-04-2014, 06:05 PM Thread Starter
huskerconan
1987 YJ Wrangler
Thought I'd add, JeepGuy, its posters like you that make this the best jeep site. I don't post much, ask a few questions. There is always someone who helps no matter the subjest. Never have to go anywhere else. Thanks again
