I have a d30/35 combo in my dd. I also wheel it pretty hard and am taking it to a ORV park at the end of the month and am worried about breaking an axle shaft. I have 3.73's in said jeep and I have a parts jeep with d30/35 combo but 4.10's. Will the axle shafts work out of the parts jeep for my dd if I break one?
They should. What year are the parts shafts? Same gen will work. If 95 the front ujoint might be bigger (297 instead of 260 series) they'll still fit just don't try and put the wrong size joint in it one day
Is the parts Jeep a disconnect axle? Is your Jeep a disconnect axle? (Passenger front).
Is your D35 C-clip? Is the parts D35 C-clip?
I think you'd be pretty hard pressed to break an open D30/D35 unless there's lots of binding, bouncing, or throttle. I'd be more worried about the front axle U joints if they are 260's.
They'll work. I would try the swap first in the shop under perfect conditions so you know what to do on the trail later. It's always nice to know how you're getting home if you break something.
THe first time will take forever! Once you get the hub off sand down the area that goes into the axle. It will help slide in easier.
I have 7 complete hub/u joint/shaft setups to change on the trail. I can change one in 20 minutes
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
