Swapping axle assemblies 1995 to 1990 - JeepForum.com
post #1 of 8 Old 08-31-2011, 12:11 PM Thread Starter
1990UAV
I found a good deal on complete axle assemblies (4:11 gears) off of a 1995 that I'd like to swap into my 1990 YJ.
Is there anything special I need to know, since the rear end in the 1990 is a non-clip?
1990UAV is offline
post #2 of 8 Old 08-31-2011, 09:00 PM
timatoe
timatoe's Avatar
The '95 uses a switch at the CAD on the front axle to actuate the 4WD light on the dash, so I'd use the CAD housing/cover off the '90. Otherwise everything else should basically bolt up.
timatoe is offline
post #3 of 8 Old 08-31-2011, 10:39 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You're going to end up with the larger ujoints in the front end. Bonus!
Luck Favours The Prepared
Anticanman is offline
post #4 of 8 Old 09-01-2011, 08:41 AM Thread Starter
1990UAV
Thanks for the information Timatoe. Anticanman, I saw in your profile that you are running 35's with 4:11 gears. How does it run down the highway? I currently run 32's with 3:07's,and I'm now debating if swapping the 4:11 axles is going to make enough of a difference to be worth the effort and risk. (my current axles have less than 100 k miles the new 165K +)
1990UAV is offline
post #5 of 8 Old 09-01-2011, 08:46 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Trust me, you'll see the difference. I had 3.07 and 31's and the power is about the same with 4.10 and 35's. For me it's great on the freeway and if you're running 32's you'll probably want to move up to 33's or even 35's if you do any commuting. I wouldn't recommend my set up for serious crawling unless you have low transfer case gears.
post #6 of 8 Old 09-01-2011, 11:47 AM Thread Starter
1990UAV
That is just what I wanted to hear! Thanks for the "push".
1990UAV is offline
post #7 of 8 Old 09-01-2011, 03:28 PM
Jones-Maryland
I believe the front brake caliber designs are different, you'll need to grab the 95 calibers with the axle
Jones-Maryland is offline
post #8 of 8 Old 09-01-2011, 05:53 PM
timatoe
timatoe's Avatar
I've got the calipers from a '95 XJ on the stock front end of my '90. No issues. Autozone and Kragen list the '90 and the '95 with the same part number.
timatoe is offline
1990 and 1995 cj 4.0l pilot hole BAD007SUBARU YJ Wrangler Technical Forum 6 01-10-2011 03:16 PM
1990-1995 wrangler same parts mina678 YJ Wrangler Technical Forum 5 10-04-2008 12:12 PM
swapping transfer case 1990 YJ GiggityJeep YJ Wrangler Technical Forum 3 04-18-2007 12:03 PM
Install Lockers - or all new axle assemblies mafjord TJ Wrangler Technical Forum 6 01-12-2007 03:04 PM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
