swapped 8.8 now brake light on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > swapped 8.8 now brake light on
Black Rhino Off Road Wheels + Free ShippingThe ULTIMATE "Selectable" Locker System! BroughRough Country Lift Kits and Parts!
Unread 06-05-2014, 07:05 PM   #1
Jeepyj311
Hey guys I finally swapped in the 8.8 with the help of my buddy. I was called off to work as we were finishing and he said he would just put the brakes back on for me. Well when I got back to get my jeep and drove it I noticed my brake light was staying lit on the dash and the brakes were way too soft. I looked at it more thoroughly this evening and noticed the calipers were put on upside down. Because of this he probably wasn't able to bleed the brakes all the way. Could this be making the brake light stay on? Also, I have read of some people taking out the o-ring in the in the metering shaft in the proportioning valve....but never understand the reason behind this. Does doing that help stopping power? Thanks for all input guys
Jeepyj311 is offline   Reply With Quote
Unread 06-05-2014, 07:38 PM   #2
Jeepsr4me
dont take out anything. And bleed the brakes and the light will go off.
Jeepsr4me is offline   Reply With Quote
Unread 06-05-2014, 07:54 PM   #3
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by Jeepsr4me View Post
Don't take out anything. Swap the calipers from one side to the other, bleed the brakes and the light will go off.
Fixed it for you!
I agree.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-05-2014, 08:24 PM   #4
Jeepsr4me
Yeah he mentioned ed the calipers in wrong spot
Unread 06-06-2014, 09:59 AM   #5
Randonexplosion
Trailer Queen
Randonexplosion's Avatar
If the light is still on after you swap the calipers and bleed, give the pedal a nice hard stomp. That what my mechanic friend told me to do and it worked. Ive read it somewhere as well.
5.3/4l60e swap
August YJOTM
Exiled Offroad - Colorado
Randonexplosion is offline   Reply With Quote
Unread 06-06-2014, 10:22 AM   #6
jbolty
jbolty's Avatar
what they said ^^^.
Chances are the proportioning valve shut off the flow to the rear because the lack of pressure was interpreted as a failure of that circuit. You may need to re-center the shuttle in the valve by hand. Unscrew the brake light switch on the prop valve an see if the shuttle valve is centered; if not you can move it with a small pick.
This is not a jeep valve but is an almost identical design. When the shuttle goes off center it makes the ground that turns on the light.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
