Swap or update - JeepForum.com
post #1 of 3 Old 01-31-2012, 06:37 PM Thread Starter
Sliver
1987 YJ Wrangler
Swap or update
Hello and TIA,
I have an 87 YJ 4.2 carter carb (rebuilt) automatic. Body is great, engine has only 119k on it. Wants are, better starting, more power, better fuel economy. Please rate the options.
1) swap out for a newer 4.0 with FI (have a 98 in mind that sounds OK) $$
2) Howell FI $$$
3) Head swap to a 4.0 with FI ???
4) Switch out to a new Weber carb. $
Sliver is offline
post #2 of 3 Old 01-31-2012, 06:47 PM
gbeltran
I'd skip the Weber (or any other carb for that matter). Howell will be the easiest of the EFI swaps that you have listed. I think you can modify the 4.0 EFI manifold to fit the 4.2 head so you don't have to swap heads if you want to go that route, that's what the Mopar EFI conversion kit uses. Me, I'd go Howell, but I'm biased since that's what I used.
gbeltran is offline
post #3 of 3 Old 01-31-2012, 06:57 PM
Collin89Sahara
If I had the money I would buy the 4.0, stroke/rebuild, that way I have a brand new fresh engine. Just my $.02
Collin89Sahara is offline
UPDATE: hi-amp alternator swap sduncan TJ Wrangler Technical Forum 75 11-10-2012 05:49 PM
Chevy Small block swap update Atropine YJ Wrangler Technical Forum 6 11-27-2009 08:54 PM
Update of 6.0 swap. simadownow6988 TJ Wrangler Technical Forum 28 11-16-2009 06:03 PM
update on my 4cyl to 6cyl swap duglas25 TJ Wrangler Technical Forum 9 03-08-2008 06:42 PM
Maaco Update: Update! ZonaWrangler YJ Wrangler Technical Forum 2 05-24-2005 07:53 AM
