Swap to external slave - JeepForum.com
post #1 of 4 Old 09-18-2006, 12:51 AM Thread Starter
Fenix85182
Fenix85182's Avatar
I'm gearing up for a big motor/tranny swap. I'm going from a 4.2 paired with an AX-15 (with internal slave) to the 4.0 with an NV3550. Assuming I can't get the proper clutch pieces from the NV3550, I need some information. Also note, I'm going to be going with the Centerforce II plate and disc.
Now... will I need anything special for the rest of the clutch? I should just be able to purchase a throw out bearing for an '02 Wrangler and I should be set, right?
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #2 of 4 Old 09-18-2006, 05:49 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Should be. But you may need a new master as well if the current one doesn't "throw" as far.
Make sure you get the clutch, pressure plate for the year/size of the motor, not the trans. You're mounting all this to the 4.2 flywheel regardless of trans behind it.
Not sure on the throwout bearing on a NV.
- Ernie
Richmond88yj is offline
post #3 of 4 Old 09-18-2006, 10:28 AM Thread Starter
Fenix85182
Fenix85182's Avatar
4.2 flywheel? I was planning on using the 4.0 flywheel that came with the donor motor.
In case I wasn't clear (which is a very distinct possibility), the 4.2 is coming out and a 4.0 is going in.
Either way, I think you're right, I think I may need the master cylinder for the 4.0 motor. I'll have to check part numbers and see if they line up...
Thanks!
post #4 of 4 Old 09-19-2006, 08:50 AM
Richmond88yj
Eat, Sleep, Jeep
You're right, 4.0. (meaning match clutch to whatever flywheel, not the trans)
- Ernie
Leans AX-15 External Slave Swap With Pics! Leans93 YJ Wrangler Technical Forum 178 06-28-2016 03:10 PM
External to internal Slave swap, can it be done??? rustywrangler YJ Wrangler Technical Forum 1 12-02-2009 05:32 AM
Help: external clutch slave cylinder swap Blacksmith13 YJ Wrangler Technical Forum 0 02-26-2009 08:47 AM
Completed External Slave Swap rbn1357 YJ Wrangler Technical Forum 0 08-28-2006 02:05 PM
Internal/External Slave swap TellyDSP YJ Wrangler Technical Forum 13 05-04-2005 08:26 PM
