#1 | |
Swap AX-15 for BA-10/5? problems?
Working on a friends 89 YJ with a I6 258 and NP231 xfer case, but the BA-10/5 is gone again! What does it take to swap in an AX-15 to replace the Pukego? Pros and cons?
88 Wrangler, 4.5" Rubicon Express Extreme springs, custom shackle lift, 3" body lift; 4th 258 I6 bored .030 over with HEI ignition and RV cam, Weber carb, ported head/intake and headers; SYE and a Woody; Detroit locker rear 30-spline D35, Power-lok front D30, 4.10 gears and 36x12.50 Super Swamper TSL; custom axle u-bolt swap with nuts on top; raised all 4 lower shock mounts flush with tubes after destroying stock ones in Tellico; 4-wheel disc brakes; dual Optima yellowtops, Ramsey 8000 with dash remote, soon to be fully caged; Survived Tellico Rock Garden and Ledge with a Peugeot BA-10/5 tranny - but the Peugeot has now been swapped for an AX-15...I finally saw the light! |
#2 |
Help a YJ in need!
Surely some hacker out there has replaced their Pukego BA10/5 for something better (wouldn't take much). Help a pal out who is severely depressed looking at his YJ laying lifeless in the side yard!
#3 |
On the BA/10 there's 21 spline on the output shaft while on the AX15 there are 23. Also in order to use the AX15 you have to replace the input gear of your NP231 transfer case to a 23 spline. You can easily obtain these parts from Advance Adapters.
You can still use the old clutch disc, pressure plate and pilot bearing if they are in very good condition or if you elect but not the throw-out bearing and the slave cylinder assembly (these need to be from an AX15). Be sure to think safety when doing this job and don't forget to use a transmission tray/jack. Good Luck and Regards |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
