Swap - JeepForum.com
post #1 of 1 Old 05-20-2001, 11:06 AM Thread Starter
Razskidoo
Swap
I changed my mind ,I'm going with a 350 small block and 350 turbo trans .
The trans is a auto and the jeep is set up for a stick , what do I need to make the auto trans compatible? and will the transfer case adapt to the trans?
92 Wangler ,I-6 ,3"lift, 32x12.5
Razskidoo is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
