Swap 70's amc I6 into my yj? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Swap 70's amc I6 into my yj?
*STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year saleRegear now with Gear Packages from JeepHut.com
Unread 02-15-2013, 07:14 PM   #1
70worm
1977 CJ5
I have a 91 Wrangler and would like to put a 70's 258 or 232 in it. Is it a direct swap? Are the motor mounts the same? Will thebAUTO trans bolt up?
70worm is offline   Reply With Quote Quick reply to this message
Unread 02-15-2013, 08:00 PM   #2
crackedcornish
whether it is a direct bolt in swap or not I don't know, but check with your local dmv as to the legality of such a swap. most places you need a motor of the same year or newer than the vehicle your installing it into.
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline   Reply With Quote Quick reply to this message
Unread 02-15-2013, 09:32 PM   #3
dillonjm
I suppose you could, the mounts and stuff won't be the same though.
That said, I wouldn't go from fuel injection to a carb setup like you're proposing if it were me. A 4.0 Swap would be a better option. Still have the same issues of mounts/transmission/t-case etc.
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
