Swap 70's amc I6 into my yj? - JeepForum.com
post #1 of 3 Old 02-15-2013, 06:14 PM Thread Starter
70worm
1977 CJ5
I have a 91 Wrangler and would like to put a 70's 258 or 232 in it. Is it a direct swap? Are the motor mounts the same? Will thebAUTO trans bolt up?
70worm is offline
post #2 of 3 Old 02-15-2013, 07:00 PM
crackedcornish
whether it is a direct bolt in swap or not I don't know, but check with your local dmv as to the legality of such a swap. most places you need a motor of the same year or newer than the vehicle your installing it into.
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 3 Old 02-15-2013, 08:32 PM
dillonjm
2013 WK
I suppose you could, the mounts and stuff won't be the same though.
That said, I wouldn't go from fuel injection to a carb setup like you're proposing if it were me. A 4.0 Swap would be a better option. Still have the same issues of mounts/transmission/t-case etc.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
