Suspension Tech - JeepForum.com
post #1 of 19 Old 07-03-2012, 10:51 AM Thread Starter
calpbs
Suspension Tech
I have a 4' ROUGH COUNTRY lift and a shackle reversal on my YJ. My question is the front shackle supposed to be straight up and down or is it supposed to be canted forward or aft? Secondly I have read several comments about removing the track bars front and rear, Will this take away street manners in lieu of off road manners? Will this weaken the suspension? I have all new poly graphite bushings in the springs? Just wondering if I am making my jeep handle poorly by leaving them on?
I have done so much with so little for so long, I can do anything with nothing forever.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #2 of 19 Old 07-03-2012, 10:58 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
The track bars don't really change on road handling. It really depends on how you like it though. They do however bind the suspension making the ride a little worse. Take them off and drive with it for a week, if you don't notice a difference put them in the scrap pile. If you do, and you don't like it, put them back on but make sure you have extension brackets. But the latter is highly unlikely.
And as for the shackles I think they are suppose to be aft a bit. Not sure though so don't quote me.
Michaelgoesrawr is offline
post #3 of 19 Old 07-03-2012, 11:23 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The shackles are supposed to be in a position that when the spring compresses, it's already allowing the shackle to move away from it. Having it pull back in is going to fight the spring and make your terrible springs ride even worse
Luck Favours The Prepared
Anticanman is offline
post #4 of 19 Old 07-03-2012, 11:28 AM
Nafpu
2012 KK Liberty
I'll second the tracbar removal. It really helps to make those agressive speed bumps less bone-jarring. Can you post a pic of your shackles with a load on the springs? That way we can better answer your question about shackle angle. Check this link and see if it answers your questions...
http://www.jeeptech.com/susp/elkcahs/index.html
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #5 of 19 Old 07-03-2012, 01:53 PM
Siva283
I think what he is trying to say here is it should be canted slightly forward. However straight up and down should be ok. If it is canted aft at all that would be bad and fight what the spring is trying to do because oif the arc of motion the shackle makes.
Physics is your friend.
Ask me how I know...
Siva283 is offline
post #6 of 19 Old 07-04-2012, 07:17 AM Thread Starter
calpbs
Here is where the shackle rides.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #7 of 19 Old 07-04-2012, 07:27 AM
Siva283
The angle looks fine to me. That looks like one long *** shackles though. You should consider shortening them. Your springs will thank you. Your steering will too.
Sent from my EVO 4G using JeepForum
Siva283 is offline
post #8 of 19 Old 07-04-2012, 07:47 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I don't think the steering is as much affected by a shackle of that length and a srs
post #9 of 19 Old 07-04-2012, 08:23 AM
Nafpu
2012 KK Liberty
Keep in mind that his shackles are reversed, so the bottom of the front shackle (if not straight up and down) should be pointed slightly to the rear while at rest. The OP's shackle angles look fine...
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
post #10 of 19 Old 07-04-2012, 08:33 AM
Nafpu
2012 KK Liberty
Upon further review of your pic, you might want to consider getting a different front driveshaft that can collapse more when the axle moves back under compression. Right now it looks like you could be putting tremendous pressure on your transfer case every time you load the springs on even a speed bump since the drive shaft can't compress any more than it is currently sitting at rest.
This area needs to have a space at the slip joint for expansion/compression
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
post #11 of 19 Old 07-04-2012, 08:35 AM
RockWoRM
RockWoRM's Avatar
I'm curious as to what shackles are in the rear? Those do look a bit long. I would consider a smaller pair as long as it does'nt make the nose dip. And yes, ditch the tracs, but keep the sway. .$o2
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #12 of 19 Old 07-04-2012, 09:08 AM Thread Starter
calpbs
Thanks, that front drive shaft may be my vibration. I am getting ready to regear to 4.10's so I am doing a complete front end rebuild. Believe that drive shaft needs delt with today though.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #13 of 19 Old 07-04-2012, 10:08 AM
Siva283
You are correct. I didn't notice the shackles reversal. Pics are small on my phone.
Siva283 is offline
post #14 of 19 Old 07-04-2012, 01:13 PM Thread Starter
calpbs
Well the front driveshaft is tight and I will shorten it about 2 inches so it will have no chance to bind, it is removed for now. I test drove it and still have the vibration at 20 mph. I checked the toe and it was 1/2 inch toed out. I adjusted it to zero toe. The vibration improved. I did discover the pitman arm was loose so I tightened it as well. Still have the 20 mph vibration but less pronounced. I removed the front track bar to no change. I am going to remove the rear track bar next but with low expectations. The shackles are the same legnth on both front and rear, I could drill holes in the front shackle to shorten them, not sure if that will help. I do plan on replacing the ball joints. I cant figure the vibration, hope its the driveshaft balance.
Charlie Lamar
Ringgold, GA
calpbs is offline
post #15 of 19 Old 07-04-2012, 07:04 PM
Nafpu
2012 KK Liberty
Do you have a new rear driveshaft with an SYE kit? T-case drop? How are your driveline angles?
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
Long Arm suspension...vs short arm suspension GMC7000 TJ Wrangler Technical Forum 105 11-09-2010 08:46 PM
Rubicon suspension vs. Islander/Mountain suspension GXP20T JK Wrangler Technical Forum 11 08-25-2010 07:54 PM
OME 2.5'' suspension kit or Rancho 2.5'' Rockcrawler suspension kit? billabong266 TJ Wrangler Technical Forum 23 04-23-2009 01:05 PM
best tech write up for a 3.5 suspension lift rolledthatho YJ Wrangler Technical Forum 5 03-09-2006 12:11 AM
