Suspension lift on 29" tires?? - JeepForum.com
post #1 of 10 Old 05-31-2001, 12:03 AM Thread Starter
Tony & his 91' YJ
This is my first post. In case you were wondering?? I have a 91 YJ and was told by a 4x4 shop that they can install a 2.5" lift w/out any problems for about $800. Is this too much and will it work without lookin like total S#it??? -Tony
Tony B.
1991 Jeep Wrangler YJ
2.5 liter Herculined, 2.5 ProComp Suspension lift, 1.4 shackle lift, New Gibson Exhaust,31 Pro Comp Mud Terrain, Olympic Grill guard, Olympic Brush guard, smittybuilt nerf bars with step, Hella 550
91 YJ
/____\
{OlllllO}
Tony & his 91' YJ is offline
post #2 of 10 Old 05-31-2001, 12:19 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
??? Including the following I'd hope
- new springs
- new shocks
- transfer case drop spacers
- sims for the axles
- track bar relocation brackets
- new u-bolts
- extended bumpstops
- brake line relocation
& without a body lift or extended shackles
and it should look something like this
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 10 Old 05-31-2001, 02:46 AM
Tonka
2015 JK Wrangler
Save some money, grab a friend or two and do it yourself. That should drop the price to 500 to 600 dollars and a case of beer
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 10 Old 05-31-2001, 11:31 AM
damonejeep
I agree with Tonka. If you have any mechanical knowledge or are atleast decent with your hands and directions, they are not terribly difficult.
One more thought to consider, are you going to be offraoding or is this just for looks? If you will be using your Jeep for its designed purpose, why not go with a higher lift: 3.5", 4" or 4.5". I recently purchased a BDS 3.5 lift from JimsOffroadWarehouse.com for about $500, and a 1" body lift. This has given me around 4.5" of lift. However, you will need new shocks, but in the end I think you will be happy with a taller lift.
Just another option to consider.
Good luck and welcome to the forum.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #5 of 10 Old 05-31-2001, 01:06 PM
rayray
rayray's Avatar
Tony,
That actually sounds a bit steep. If you would like, I know some people out in SA that could help you out. Like mentioned earlier, beer and pizza are typical compensation.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #6 of 10 Old 05-31-2001, 02:24 PM Thread Starter
Tony & his 91' YJ
Tony B.
91 YJ
/____\
{OlllllO}
post #7 of 10 Old 05-31-2001, 02:47 PM Thread Starter
Tony & his 91' YJ
Thanks damonejeep. Mainly I want it for what it's for. Off roadin! However, I don't want it to look retarded all jacked up with little *** tires. That's what my first concern is. -T
Tony B.
91 YJ
/____\
{OlllllO}
post #8 of 10 Old 05-31-2001, 02:50 PM Thread Starter
Tony & his 91' YJ
That't cool rayray. I'm up for da pizza and beer. My concern is that I want it done right the first time. I don't know who these people are but I don't want it all rigged half ***. Shoot me an email so we can all hook up sometime. I'm not lookin to do anything for about a week or two. Where's the best place to but the kit? -T
Tony B.
91 YJ
/____\
{OlllllO}
post #9 of 10 Old 05-31-2001, 06:47 PM
rayray
rayray's Avatar
I sent you an email with some info.
rayray
rayray is offline
post #10 of 10 Old 05-31-2001, 09:27 PM
Tonka
2015 JK Wrangler
Its hard to screw up a lift, and I know of 3 people running 215's with 4.5 inches of lift on their 2 tj's and one yj. spend $3.00 on some stickers and put "under construction" on the jeep somewhere. If you frequently offroad, then the goofy looks and a larger lift are the way to go. Remember that your rig will only be that way temporarily and it will save you some cash in the long run.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
2" OME suspension lift w/ shocks & Springs. Not theBB or the2.5" lift CCJ TJ Wrangler Technical Forum 46 08-27-2009 01:44 AM
what size suspension lift for 33" tires ejh2205 TJ Wrangler Technical Forum 31 04-15-2008 09:16 PM
Completed a 2" suspension lift and tires Paid Up TJ Wrangler Technical Forum 9 11-10-2007 07:38 AM
What kind/size suspension lift for 32" tires MBrit13 YJ Wrangler Technical Forum 10 10-13-2004 09:15 AM
