-   -   Suspension lift on 29" tires?? (http://www.jeepforum.com/forum/f12/suspension-lift-29-tires-9406/)
Tony & his 91' YJ 05-31-2001 12:03 AM
This is my first post. In case you were wondering?? I have a 91 YJ and was told by a 4x4 shop that they can install a 2.5" lift w/out any problems for about $800. Is this too much and will it work without lookin like total S#it??? -Tony
FLHT_FXRS_YJ 05-31-2001 12:19 AM
??? Including the following I'd hope
- new springs
- new shocks
- transfer case drop spacers
- sims for the axles
- track bar relocation brackets
- new u-bolts
- extended bumpstops
- brake line relocation
& without a body lift or extended shackles
and it should look something like this
http://a676.g.akamai.net/f/676/987/1...ko3mk/89yj.jpg
Tonka 05-31-2001 02:46 AM
Save some money, grab a friend or two and do it yourself. That should drop the price to 500 to 600 dollars and a case of beer :D
damonejeep 05-31-2001 11:31 AM
I agree with Tonka. If you have any mechanical knowledge or are atleast decent with your hands and directions, they are not terribly difficult.
One more thought to consider, are you going to be offraoding or is this just for looks? If you will be using your Jeep for its designed purpose, why not go with a higher lift: 3.5", 4" or 4.5". I recently purchased a BDS 3.5 lift from JimsOffroadWarehouse.com for about $500, and a 1" body lift. This has given me around 4.5" of lift. However, you will need new shocks, but in the end I think you will be happy with a taller lift.
Just another option to consider.
Good luck and welcome to the forum.
rayray 05-31-2001 01:06 PM
Tony,
That actually sounds a bit steep. If you would like, I know some people out in SA that could help you out. Like mentioned earlier, beer and pizza are typical compensation.
Tony & his 91' YJ 05-31-2001 02:24 PM
Tony & his 91' YJ 05-31-2001 02:47 PM
Thanks damonejeep. Mainly I want it for what it's for. Off roadin! However, I don't want it to look retarded all jacked up with little *** tires. That's what my first concern is. -T
Tony & his 91' YJ 05-31-2001 02:50 PM
That't cool rayray. I'm up for da pizza and beer. My concern is that I want it done right the first time. I don't know who these people are but I don't want it all rigged half ***. Shoot me an email so we can all hook up sometime. I'm not lookin to do anything for about a week or two. Where's the best place to but the kit? -T
rayray 05-31-2001 06:47 PM
I sent you an email with some info.
Tonka 05-31-2001 09:27 PM
Its hard to screw up a lift, and I know of 3 people running 215's with 4.5 inches of lift on their 2 tj's and one yj. spend $3.00 on some stickers and put "under construction" on the jeep somewhere. If you frequently offroad, then the goofy looks and a larger lift are the way to go. Remember that your rig will only be that way temporarily and it will save you some cash in the long run.
The time now is 02:10 AM.
