suspension bolt torque? - JeepForum.com
post #1 of 4 Old 02-15-2013, 06:42 PM Thread Starter
jetboat
1987 YJ Wrangler
I pieced together my lift so I dont have any instruction... Whats the torque on all the bolts supposed to be (on the ground with vehicle weight).
jetboat is offline
post #2 of 4 Old 02-15-2013, 07:42 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Go to one of the more popular (read - reliable/quality) suspension kit company's website (EG: RE, BDS etc) check the torque listed in the install instructions.
Adjust as you see fit. EG: Lots of folks torque the suspension bushing bolts on the shackles to less than is typically listed as long as you are using a nylock nut.
Joe Dillard is offline
post #3 of 4 Old 02-15-2013, 08:07 PM
laffman
45 ft lb.
1990 Jeep YJ Laredo 4.2 I-6
2010 Jeep JK Islander 3.8 V-6
1982 Jeep CJ-8 Scrambler 304 V-8
laffman is offline
post #4 of 4 Old 02-15-2013, 09:22 PM
5-90
5-90's Avatar
1988 XJ Cherokee
www.kelleyswip.com/tech.html. If I've got an FSM for your year (or close to it,) specs are there. I do have a few to add - but all specs are from factory literature.
NB: Snug the bolts up with the vehicle in the air, but put it on all four tyres and "bounce" the bumper a couple of times before you actually torque them - back them out about a half-turn from "snug" then torque them down.
Why? If you torque things down with the suspension at full droop, you're going to incorrectly preload your bushings, and mightily accelerate bushing wear!
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
