superlift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > superlift
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 10-09-2007, 06:40 PM   #1
ionakana
Grand Poobah
ionakana's Avatar
superlift
A friend has new 3.5" Superlift springs he has never installed. He decided to go SOA and has given me first dibs on the springs. Does anyone run these? I don't need them but I wouldn't mind having them to get another 1" of lift. If they have problems with sagging or anything else I'll pass them up and wait for a Rubicon express down the road. I did a search and came up with nothing.
Psalm 14:1
http://www.oddhammer.com/tutorials/d...debt_clock.swf
Live in Georgia? click here--> http://georgiacrawlers.com/
ionakana is offline   Reply With Quote
Unread 10-09-2007, 09:49 PM   #2
MNKMcNeilly
I had 3.5" Superlift springs, and I thought they were great. The ride was much better than my buddies YJ with 3.5" springs. I am not sure what brand, He bought it with them. Anyway, I would still be running them if I hadn't gone SOA. I give them
Green 1993 Jeep YJ with black hardtop 4.0, 4.11 gears,SOA with 1.5" lift springs, Ford 8.8, 3/4" lift Shackles, 35" BFG MT's on black Pro-Comp Rockcrawler wheels, Front OX Locker, Ramsey 8.5 winch, Hand Throttle, Bushwacker style cut out fenders, JB4x4 high steer
[url]www.4x4him.org[/url]
[url]www.effectradio.com[/url]
MNKMcNeilly is offline   Reply With Quote
Unread 10-09-2007, 11:10 PM   #3
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
i hated my 3.5" superlift's SOA..... and i'm referring to the ride, NOT the height....
-Erik <--- would stick with OME or BDS
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Unread 10-10-2007, 06:17 AM   #4
Michael_94YJ
I just installed the 3.5' Superlifts but the jeep won't be driveable until this weekend but i'll keep ya posted.
1994 YJ 4.0L 5 spd.
flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works
http://i178.photobucket.com/albums/w...y/Image075.jpg
Michael_94YJ is offline   Reply With Quote
Unread 10-10-2007, 07:35 AM   #5
GrimJeeper91
My YJ had Pro-Crap springs on it when I bought it. The Superlift springs were a much better spring. Better ride and better flex. I'd go for it if he gives you a deal.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline   Reply With Quote
Unread 10-10-2007, 07:41 AM   #6
ionakana
Grand Poobah
ionakana's Avatar
yea, I put pro comp springs on my Jeep before I found JF and learned I should have bought something else. Mine have been okay except one is sagging, just got to get around to take it off and get a new one under warranty. They flex okay and ride okay, it took alot of flexing to loosen them up a little though but I want to go higher now. The 3.5" springs and my 1" body lift will work nice I think. He's offering me a deal, I still need everything else to go with them though.
Psalm 14:1
Unread 10-10-2007, 07:48 AM   #7
Michael_94YJ
What else do you need that your current lift doesn't have? SYE & driveshaft?
1994 YJ 4.0L 5 spd.
Unread 10-10-2007, 08:22 AM   #8
ionakana
Grand Poobah
ionakana's Avatar
yep, the sye and driveshaft, longer brake lines and swaybar disconnects. That's about it. Not sure if my swaybar disconnects will work. Taking off the swaybar is not an option for me. The Jeep handles alot better on the road with it.
Psalm 14:1
Unread 10-10-2007, 02:39 PM   #9
MLJeeper
I have the 3.5 supalifts for the heavier loads on mine. Ive been real pleased with them. Was suprised at how well they flexed. Ride is "OK".
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline   Reply With Quote
Unread 10-10-2007, 03:21 PM   #10
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
maybe i should add that i was unhappy with the ride MOST LIKELY b/c i run topless, doorless, and with an empty rear cargo area year round....don't want to mislead anyone....
Unread 10-10-2007, 09:11 PM   #11
jeeepguy
My first lift was a 3.5" Superlift. Worked great for 4 years and never sagged. Wheeled it every weekend.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline   Reply With Quote
