Superior super 8.8 axle seal problem - JeepForum.com
post #1 of 19 Old 06-05-2013, 02:54 AM Thread Starter
rykemc
Here is my problem, I can not get the right side axle seal to seal. It is not leaking from the inner seal to axle shaft but the outer area of the seal at the bottom of the seal. I also have about a 1/2" play of the axle in and out and also can move the axle up and down. Now when I remove my caliper bracket and dust shield and just install the axle I can get the axle tight and no play or leaking. Anyone running this setup had or having a problem like this? Left side is doing just fine.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #2 of 19 Old 06-05-2013, 03:22 AM Thread Starter
rykemc
May have figured out my problem. I did not receive and spacers with my kit. Questions for those who have ran this kit, did your get come with spacers that went between the rapetauner plate and the seal?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #3 of 19 Old 06-05-2013, 09:59 AM Thread Starter
rykemc
Bump!
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #4 of 19 Old 06-05-2013, 10:12 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There is a spacer, yes.
Luck Favours The Prepared
Anticanman is offline
post #5 of 19 Old 06-05-2013, 10:28 AM Thread Starter
rykemc
Thought so and my kit did not come with one. Crap. Guess its time to make one. Antican, is yours installed yet?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #6 of 19 Old 06-05-2013, 10:57 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I have an extra you can mock up. Lemme get back to the shop and I will get you my number.
post #7 of 19 Old 06-05-2013, 11:01 AM Thread Starter
rykemc
Great! Or if you can just get me the measurements of it I can go off that. Again thanks for the help.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #8 of 19 Old 06-05-2013, 05:11 PM Thread Starter
rykemc
I would like to thank anticanman for taking the time to get me the information I needed to fix my problem. Again good sir I want to personally thank you for everything. It is people like him who makes the jeep community so great.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #9 of 19 Old 06-05-2013, 06:37 PM
jsawduste
2006 YJ Wrangler
PM mrblaine (he is on the TJ forum) and ask him. He designed the kit for Superior and has all the knowledge/parts you need to fix your problem.
jsawduste is offline
post #10 of 19 Old 06-05-2013, 07:01 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Good call John. I traded a couple PM's with the OP & it looks like his issue is getting resolved. I'll see Blaine tomorrow to see if he has any handy in case the OP's current plan doesn't work out & so I'll know if he has any in the future.
Joe Dillard is offline
post #11 of 19 Old 06-05-2013, 07:45 PM
jsawduste
2006 YJ Wrangler
Thanks for the kind words Joe
post #12 of 19 Old 06-05-2013, 07:56 PM Thread Starter
rykemc
Joe, when you talk to him could you ask him if he has the dimensions of the spacer?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #13 of 19 Old 06-05-2013, 08:14 PM
Joe Dillard
Better yet, I'll call him right now to see if he knows off the top of his head. Like I mentioned, he may have some laying around. I'll check.
post #14 of 19 Old 06-05-2013, 08:24 PM Thread Starter
rykemc
Thank you kindly sir.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #15 of 19 Old 06-05-2013, 08:26 PM
Joe Dillard
I just got off the phone with Blaine. He doesn't have them laying around. I have two spare S88 axle shafts - but my spare axle shafts have all the parts already pressed onto them, so they can't be removed without screwing with the retaining coller, bearing, and seal.
He recommends calling Currie Ent and tell them that you need the spacer that goes between a set 20 bearing seal and the axle retainer plate for a disc equipped axle. They should be able to figure the correct part from there.
Blaine was wondering if you got the kit new, or possibly second hand?
