Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals
#1 | |
Mud tuggin!
Anyone running these??:
http://www.quadratec.com/products/52420_900.htm Do they eliminate having to worry a bunch about leaking internal seals? Adding more gear oil and putting these on? They seem like they will help with seal life anyways if i replace the seals and add these seals as well!
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon! Build thread: http://www.jeepforum.com/forum/f22/build-thread-dirty-894483/ |
#2 |
My good buddy is running the superior seals on his lifted rubi. He tells me all the time to get the Alloy seals not Superior as his superior suck and he has had problems with them. I think there was a vendor selling the Alloy seals for $55 shipped. Check out the vendor section.
93 YJ - SOLD |
#3 |
They don't work to keep gear oil in...only to keep water/mud out.
Also they don't fit on the yj with the vacuum disconnect. They work with the tj axle upgrade though. They use a lot of grease too. |
#4 |
Jeepster do you know if they fit the xj HPDana 30?
93 YJ - SOLD |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
