Superior Axle 30 spline upgrade for D35 - JeepForum.com
post #1 of 14 Old 06-30-2011, 11:39 PM Thread Starter
yjJEEPyj
i was wondering if the 30 spine upgrade from the 27 requires anything besides taking out the old and putting in the new? i heard somewhere that the axles needed to b machined out?
yjJEEPyj is offline
post #2 of 14 Old 07-01-2011, 12:43 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Your spider gears need to match the spline count on your axle shafts. This now makes the ring gear and carrier the weak point in your rear end. I'd keep the stock shafts unless you're upgrading the carrier too. Axle shafts on a dana35 are like a fuse. They blow before you damage something more expensive to fix.
Anticanman is offline
post #3 of 14 Old 07-01-2011, 03:44 AM
timatoe
timatoe's Avatar
You can't get a 30 spline carrier, you have to get a selectable locker for the application, ie. ARB or OX.
IMHO, you'd be much better off and less money getting an 8.8.
timatoe is offline
post #4 of 14 Old 07-01-2011, 06:57 AM Thread Starter
yjJEEPyj
Ya iv Ben thinking about the 8.8 but.. I can't really shorten that much at once. For my tires I had to buy two at a time cuz of money. I'm 19 and all my money is going into my jeep. But I am planning on doing the entire super35 kit.. I'm Judy going to buy the locker at a separate time as the shafts. Plus if I did do the 8.8 I would have to buy new wheels. And I just bought songs and had them all powdercoted..
yjJEEPyj is offline
post #5 of 14 Old 07-01-2011, 06:59 AM Thread Starter
yjJEEPyj
Sorry about the random words.. my phone is gay about spellcheck
yjJEEPyj is offline
post #6 of 14 Old 07-01-2011, 07:38 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
why do you think that?
from a fiscal perspective the super 35 kit is a waste of your money.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #7 of 14 Old 07-01-2011, 08:26 AM
MLJeeper
MLJeeper's Avatar
You would not have to buy new wheels with the exploder 8.8. That is one of the main reasons they are a good deal.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #8 of 14 Old 07-01-2011, 12:51 PM
mazyj
I would do alot more research into the 8.8 because it seems you dont fully understand the concept.
Super 35 Kit is roughly $1500 when all said and done. You may get the strongest D35 you can out of it but it is still however a D35 and its not uncommon to hear of them breaking.
I bought my F8.8 from a junkyard completely intact for $65. This include brake hardware, Ebrake lines, 4.10 gears (upgrade) and a Limited Slip. Mounting kit and bulletproof differential cover costs me roughly $200. I drop in a 4 cylinder (4.10) dana 30 upfront and I have upgraded my gearing, brakes, and my axle is roughly twice as strong. If i decide to go bigger then 35's I can still upgrade the unit with a super 8.8 kit and a detroit and laugh at 37's. So for Substantially less money you get far far more with the 8.8 IMO.
Anyone have the link to the thread where the guy argued and argued about his super 35 then it blew up the first day he wheeled it? It had something to do with humble pie if I recall.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #9 of 14 Old 07-01-2011, 01:35 PM
MLJeeper
MLJeeper's Avatar
I dont think it blew up the first day, LOL. I think the guys screenname was Wendell
MLJeeper is offline
post #10 of 14 Old 07-01-2011, 02:11 PM
skullysXJ
Yeah def don't waste your money on the super 35. Go for the 8.8. You'll spend just as much money as you would on a super 35 and you get a much better axle.
~KADE~ kool kid klub #1
08 JKU Rubicon
skullysXJ is offline
post #11 of 14 Old 07-01-2011, 03:16 PM Thread Starter
yjJEEPyj
What year of explorer should I look for?
yjJEEPyj is offline
post #12 of 14 Old 07-01-2011, 03:57 PM
jeepyj13
I think any model will do they all have 31 splined 8.8s. But most desired is 96-02 cause of the disc brakes. Correct me jeepers if i got my explorer yrs wrong ha. the 8.8 have the same bolt pattern as jeep so no new wheels. The axle is slightly narrow than the d35 but hardly noticable. There are ways to add width to it if it bothers you. A stock 8.8 can hold up to 36" tires. arguably 37"s but not recommended. A super 88 kit added then the 8.8 will run 37s all day. I still run d35 with 33s no issues yet but will be buying a 8.8 in the future and seems they are hottest jeep mod these days too ha
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #13 of 14 Old 07-01-2011, 06:11 PM
RockWoRM
RockWoRM's Avatar
If you''re upgrading to a duper35, then you must be planning on using it hard core. Also keep in mind you can still bend an 'ever so weak' turdy 5 axle tube even with the duper kit. It is just not worth it IMHO.
btw... exploder years are, '91-94=drum, '95-01=disc. All have 31 spline shafts.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #14 of 14 Old 07-01-2011, 07:08 PM Thread Starter
yjJEEPyj
ok i'll start hitting up the junkyards monday i guess.. how much fabing do ya gota do to make the mounts work? new spring mounts? if im gettin a new axle im gona do SOA..
yjJEEPyj is offline
Alloy USA 35 Spline Vs Superior 33 Spline, Better Choice? rastaangel TJ Wrangler Technical Forum 6 05-03-2011 01:04 PM
Superior Axle D35 upgrade ? zjbates TJ Wrangler Technical Forum 33 02-28-2010 09:56 PM
Superior Chromo D30 (30 Spline)/D44 (35 Spline) Axle Shaft P/N's??? SuperWade2 TJ Wrangler Technical Forum 2 01-02-2010 08:24 AM
30 spline axle upgrade deryk111 TJ Wrangler Technical Forum 5 05-31-2009 11:51 AM
