is it a super 35? - JeepForum.com
post #1 of 4 Old 06-18-2013, 04:40 PM Thread Starter
billybooster2
1983 CJ8
is it a super 35?
How can I tell from a visual external inspection if an axle is super 35 or not on a wrangler 93. I suspect the transfer case (now missing) had a sye. Vehicle has a lift. Running 32's.
On a CJ AMC20, you can see a one piece axle compared to a two piece.... but is there a way for the 35?
IF i open diff what would i be seeing? Would diff cover be different at all?
thanks guys..n gals...
billybooster2 is offline
post #2 of 4 Old 06-18-2013, 05:04 PM
jeepster93
jeepster93's Avatar
Well, you can certainly tell if it is locked, anyhow.
Jack up the rear and spin a tire, if the tires turn the same way- locked, if the turn the opposite direction- unlocked.
Super is a spline count on the 35(from 27 to 30 splines). Beyond counting....
jeepster93 is offline
post #3 of 4 Old 06-18-2013, 05:11 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Pull the axleshafts 27 spline = stock shaft. 30 spline = polished turd
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 4 Old 06-18-2013, 05:23 PM
jbolty
jbolty's Avatar
Super 35 has a mounting flange and pressed on bearings. You will have to at least take of the tire and brake drum to get a look.
Normal D35 axle will not pull out unless the C clip is removed or it's broken.
jbolty is offline
